Do you need synchronised motion between the two MH5s?
Based on your answer to this, there will be two comparable, but slightly different answers (note: I'm assuming you want to use motoman_driver
, if not, please clarify your question or ignore my answer):
If synchronised motion is not required: you don't need to connect them to the same FS100.
As to the motoman_driver
setup: you run two instances of the driver in separate ROS namespaces. Each motoman_driver
instance would connect separately to each FS100. You would get two FollowJointTrajectory
action servers, one for each controller.
If synchronised motion is required: you should probably connect them to the same FS100 and configure them as two motion groups on the controller.
There would be a single motoman_driver
instance that connects to the controller. No ROS namespaces would be necessary. You would see three FollowJointTrajectory
action servers: one for each motion group and one for the combination of all joints. Sending trajectories to the per-group action server would result in async motion (ie: each manipulator is controlled individually). Sending trajectories to the "whole robot" action server would result in synchronised motion across all joints.
Originally posted by gvdhoorn with karma: 86574 on 2019-03-06
Comment by A_YIng on 2019-03-06:
Thanks for your reply, I exactly use motoman_driver in my project.
I would like to know how to connect two robot arm to the same FS100.
Any hardware should I get ?
Comment by gvdhoorn on 2019-03-06:
That would be something to ask your local Yaskawa branch office.
OK. I have the last question. Does this motoman_driver 'Inform' be suitable for this condition ?
Probably. Perhaps @millete can add something here. It all depends a bit on how things are set up on the controller.
