Hey, dear all, Recently, I am integrating ros industrial with dual Staubli TX90 arm. Actually, a package for the single arm has been developed at staubli_experimental. We have tested and ran well each controller. But my case is: I need to communicate and control dual arm. And each controller has its own ip address. for instant, left_arm[192.168.169.1], right_arm[192.168.169.2].
Here are what I have done:
- I studied motoman_driver, and in its case, the industrial::smpl_msg_connection::SmplMsgConnection connet with one robot_ip can connect two controllers. Since I have not used motoman sda series ever, I guess motoman has integrated two controller hardware in one ethernet port.
- I am rewriting the original staubli-ROS-I to support for dual arm connecting. I intend to use two connect and motoman-like group to manage the states and commands.
And I am here to asking:
- For anyone who have used motoman sda or have experiments with motoman_driver: Is it right that motoman has only one hardware ethernet ip address to connect two controllers? So the motoplus or controller app will send all states or receive command in one port? How they can pub all states in only one /joint_states?
- For anyone who have experiments with ROS-I: Is it right to go that I use use two connect with two standalone ip address? How to handle two controller states and commands in one topic, /joint_states, and /joint_trajectory_command? For Q2, I am synchronously coding, it is a really heavy work. I hope anyone could give me advice or a yes to go.
Originally posted by Hao Deng on ROS Answers with karma: 23 on 2017-06-15
Comment by gvdhoorn on 2017-06-27:
@Hao Deng: could I ask you to please mark the question as answered by ticking the checkmark to the left of the answer? It should turn green.
That would much more clearly mark this question as answered than when you close it.
Thanks.
