I would like to send a series of poses to Move Base, and have my robot follow these poses. I am using Move Base Flex, which extends a few extra actions compared to the regular Move Base. I am currently trying to understand how to use ExePathAction.
From what I understand, it allows the controller (i.e. the base local planner) to follow a set of poses. I am trying to give it 5 poses each 0.1 cm apart. What I've written so far:
#include "ros/ros.h"
#include <actionlib/client/simple_action_client.h>
#include <move_base_msgs/MoveBaseAction.h>
#include <mbf_msgs/ExePathAction.h>
#include <mbf_msgs/GetPathAction.h>
#include <mbf_msgs/MoveBaseAction.h>
#include <nav_msgs/Path.h>
typedef actionlib::SimpleActionClient<mbf_msgs::ExePathAction> PathClient;
int main(int argc, char** argv){
    ros::init(argc, argv, "simple_path");
    PathClient pc("mbf_costmap_nav/exe_path", true); // true doesnt need ros::spin
    while(!pc.waitForServer(ros::Duration(5.0))){
        ROS_INFO("Waiting for Move Base server to come up");
    mbf_msgs::ExePathGoal target_path_;
    //move_base_msgs::MoveBaseGoal goal;
    nav_msgs::Path path_;
    path_.header.frame_id = "base_link";
    path_.poses[0].pose.position.x = 0.1;
    path_.poses[0].pose.position.y = 0.0;
    path_.poses[0].pose.orientation.z = 0.0;
    path_.poses[0].pose.orientation.w = 1.0;
    path_.poses[1].pose.position.x = 0.2;
    path_.poses[1].pose.position.y = 0.0;
    path_.poses[1].pose.orientation.z = 0.0;
    path_.poses[1].pose.orientation.w = 1.0;
    path_.poses[2].pose.position.x = 0.3;
    path_.poses[2].pose.position.y = 0.0;
    path_.poses[2].pose.orientation.z = 0.0;
    path_.poses[2].pose.orientation.w = 1.0;
    path_.poses[3].pose.position.x = 0.4;
    path_.poses[3].pose.position.y = 0.0;
    path_.poses[3].pose.orientation.z = 0.0;
    path_.poses[3].pose.orientation.w = 1.0;
    path_.poses[4].pose.position.x = 0.5;
    path_.poses[4].pose.position.y = 0.0;
    path_.poses[4].pose.orientation.z = 0.0;
    path_.poses[4].pose.orientation.w = 1.0;
    target_path_.path = path_;
pc.sendGoal(target_path_);
pc.waitForResult();
if(pc.getState() == actionlib::SimpleClientGoalState::SUCCEEDED)
  ROS_INFO("Base moved %s", pc.getState().toString().c_str());
else if(pc.getState() == actionlib::SimpleClientGoalState::ABORTED)
  ROS_INFO("Goal aborted");
else
  ROS_INFO("Base failed to move for some reason");
return 0;
However this doesn't execute. I looked at the legacy relay node which relays classic move_base goals that appear on the move_base_simple/goal topic. However, that's not what I am looking for. I would like to directly use the ExePathAction, as I want to program more sophisticated navigation behaviour in the future.
Originally posted by curi_ROS on ROS Answers with karma: 166 on 2019-01-24
Hi,
You need to specify a controller for move_base_flex to move under the controller field in the ExePathGoal message(refer to message definition linked by you under ExePathAction). This is the 'local planner' that you load in the list of controllers for move_base_flex.
P.S.: Add in the time stamp for the 'path_' header.
Originally posted by harshal with karma: 35 on 2019-01-24
Comment by curi_ROS on 2019-01-28:
Thanks, that was one of the reasons!
For future users, here is the code that works for me:
#include <vector>
#include <geometry_msgs/PoseStamped.h>
typedef actionlib::SimpleActionClient<mbf_msgs::ExePathAction> PathClient; // A client of Exe Path Action Server
    ros::init(argc, argv, "odom_path");
    int no_of_poses_in_path = 4;       // Number of poses to compose the path
    std::vector<geometry_msgs::PoseStamped> poses_(no_of_poses_in_path);
    // Fill the pose vector with zeroes
     for (int i=0; i<no_of_poses_in_path; i++){
        memset(&poses_[i].pose.position, 0, 3);
        memset(&poses_[i].pose.orientation, 0, 4);
    // Insert your series of poses here using your logic
    // Here I am using 4 poses 10 cm apart
        poses_[i].header.frame_id = "odom";
        poses_[i].pose.position.x = (0.1*i);
        poses_[i].pose.position.y = 0;
        poses_[i].pose.orientation.z = 0;
        poses_[i].pose.orientation.w = 1;
        poses_[i].header.stamp = ros::Time::now();
   // Populate the Path Message
    path_.header.frame_id = "odom";
    path_.poses = poses_;
    path_.header.stamp = ros::Time::now();
    ROS_INFO("Goal Path Planned %f %f %f %f", path_.poses[0].pose.position.x, path_.poses[1].pose.position.x,
                                         path_.poses[2].pose.position.x, path_.poses[3].pose.position.x);
   // Populate the controller and path fields (Refer to ExePath.Action)
    target_path_.controller = "TebLocalPlannerROS"; // As defined in list of controllers in your yaml
  // Interact with Action Server
  pc.waitForResult();
  else
  ros::shutdown();
Originally posted by curi_ROS with karma: 166 on 2019-01-30
