hi,
i'am quite new using ROS, and i trying to get and publish the average of 1000 msg received from the LIDAR. I'am working with python code, but i cant get anything out. i checked it in the terminal with rostopic list. if i have a problem or maybe iam getting an error with the code please help me and tell me what is the mistake with the code. till momment when i run it dont have error. maybe it has lack of information or add a new library.
Source code here:
#! /usr/bin/env python
# -*- coding: utf-8 -*-
import rospy
from sensor_msgs.msg import LaserScan # Mensaje que leeremos
import numpy as np
class nodo_control():
max_medidas = 1000
cont_medidas = 0
medidas =list()
def __init__(self):
self.scan_Pub = rospy.Publisher('promedio_laser', LaserScan, queue_size=1)
self.scan_Sub = rospy.Subscriber("/scan", LaserScan, self.laserCallback)
def laserCallback(self,msg):
self.cont_medidas=self.cont_medidas +1
self.medidas.append(msg.ranges)
if self.cont_medidas >= self.max_medidas:
arreglo_medidas= np.ndarray(self.medidas)
promedio = arreglo_medidas.mean(1)
#publicar promedio
msg.ranges=promedio
self.scan_Pub.publish (promedio)
self.cont_medidas=0
self.medidas=list()
if __name__ == '__main__':
rospy.init_node("nodo_control")
rospy.spin()
try:
nodo_control()
except rospy.ROSInterruptException:
pass
Edit: i appreciate your answered, it will help me to reorganize and modify my code. i forgot say that im quite new to python too, but i need to finish it in a record time. tnx again for your time. i'll verify all again y to tell you as soon as possible. greets.
Originally posted by asmigox on ROS Answers with karma: 5 on 2018-10-19
Comment by PeteBlackerThe3rd on 2018-10-25:
You need to move the rospy.spin()
line to the end of the your main function. At the moment executing is blocking when it reaches this so that your nodo_control()
class is never getting created.
Comment by asmigox on 2018-10-25:
its working, but it has a problem. the next lines: arreglo_medidas= np.ndarray(self.medidas)
ValueError: sequence too large; cannot be greater than 32. Do u know how i could fix it?
To initialise a numpy array from a list you need to use np.array(<your_list>)
not ndarray
. I would highly recommend adding some print statements to help you debug this, including checking the shape of the numpy array you're working with.
Comment by asmigox on 2018-10-26:
i did some changes and i added some prints like u said. for ndarray i added vstack. so i can say, its working now.
tnx for ur time man.
greets
Comment by PeteBlackerThe3rd on 2018-10-26:
Glad you've got this working. If you can accept my answer with the tick icon, then other users can see that this solution works.
Thanks.
