Problem
I reinstalled ROS1 Kinetic on Ubuntu 16.04 since I realized I had been using pip, apt, and virtualenvs in the wrong way.
In my system environment, I installed ROS Kinetic following the guidelines which worked fine. However when I run
sudo rosdep init
I get:
  File "/usr/bin/rosdep", line 3, in <module>
    from rosdep2.main import rosdep_main
  File "/usr/lib/python2.7/dist-packages/rosdep2/__init__.py", line 45, in <module>
    from .lookup import RosdepDefinition, RosdepView, RosdepLookup, \
  File "/usr/lib/python2.7/dist-packages/rosdep2/lookup.py", line 41, in <module>
    from .rospkg_loader import RosPkgLoader
  File "/usr/lib/python2.7/dist-packages/rosdep2/rospkg_loader.py", line 37, in <module>
    import catkin_pkg.package
ImportError: No module named catkin_pkg.package
I had solved this before by installing it with pip instead of with apt but this apparently isn't the recommended method. I've also encountered other similar import errors before where python doesn't recognize packages installed with apt.
Details
dpkg -L python-catkin-pkg yields:
/usr
/usr/share
/usr/share/doc
/usr/share/doc/python-catkin-pkg
/usr/share/doc/python-catkin-pkg/copyright
/usr/share/doc/python-catkin-pkg/changelog.Debian.gz
/usr/lib
/usr/lib/python2.7
/usr/lib/python2.7/dist-packages/catkin_pkg-0.4.6.egg-info
/usr/lib/python2.7/dist-packages/catkin_pkg-0.4.6.egg-info/top_level.txt
/usr/lib/python2.7/dist-packages/catkin_pkg-0.4.6.egg-info/dependency_links.txt
/usr/lib/python2.7/dist-packages/catkin_pkg-0.4.6.egg-info/entry_points.txt
/usr/lib/python2.7/dist-packages/catkin_pkg-0.4.6.egg-info/PKG-INFO
/usr/lib/python2.7/dist-packages/catkin_pkg-0.4.6.egg-info/requires.txt
/usr/bin
/usr/bin/catkin_find_pkg
/usr/bin/catkin_create_pkg
/usr/bin/catkin_test_changelog
/usr/bin/catkin_prepare_release
/usr/bin/catkin_package_version
/usr/bin/catkin_tag_changelog
/usr/bin/catkin_generate_changelog
dpkg -L ros-kinetic-catkin yields:
/opt
/opt/ros
/opt/ros/kinetic
/opt/ros/kinetic/setup.bash
/opt/ros/kinetic/lib
/opt/ros/kinetic/lib/python2.7
/opt/ros/kinetic/lib/python2.7/dist-packages
/opt/ros/kinetic/lib/python2.7/dist-packages/catkin-0.7.11.egg-info
/opt/ros/kinetic/lib/python2.7/dist-packages/catkin/workspace_vcs.py
/opt/ros/kinetic/lib/python2.7/dist-packages/catkin/package_version.pyc
/opt/ros/kinetic/lib/python2.7/dist-packages/catkin/tidy_xml.py
/opt/ros/kinetic/lib/python2.7/dist-packages/catkin/cmake.py
/opt/ros/kinetic/lib/python2.7/dist-packages/catkin/tidy_xml.pyc
/opt/ros/kinetic/lib/python2.7/dist-packages/catkin/init_workspace.py
/opt/ros/kinetic/lib/python2.7/dist-packages/catkin/terminal_color.py
/opt/ros/kinetic/lib/python2.7/dist-packages/catkin/test_results.py
/opt/ros/kinetic/lib/python2.7/dist-packages/catkin/environment_cache.py
/opt/ros/kinetic/lib/python2.7/dist-packages/catkin/workspace.py
/opt/ros/kinetic/lib/python2.7/dist-packages/catkin/find_in_workspaces.py
/opt/ros/kinetic/lib/python2.7/dist-packages/catkin/find_in_workspaces.pyc
/opt/ros/kinetic/lib/python2.7/dist-packages/catkin/builder.pyc
/opt/ros/kinetic/lib/python2.7/dist-packages/catkin/init_workspace.pyc
/opt/ros/kinetic/lib/python2.7/dist-packages/catkin/__init__.py
/opt/ros/kinetic/lib/python2.7/dist-packages/catkin/__init__.pyc
/opt/ros/kinetic/lib/python2.7/dist-packages/catkin/environment_cache.pyc
/opt/ros/kinetic/lib/python2.7/dist-packages/catkin/workspace_vcs.pyc
/opt/ros/kinetic/lib/python2.7/dist-packages/catkin/cmake.pyc
/opt/ros/kinetic/lib/python2.7/dist-packages/catkin/terminal_color.pyc
/opt/ros/kinetic/lib/python2.7/dist-packages/catkin/test_results.pyc
/opt/ros/kinetic/lib/python2.7/dist-packages/catkin/workspace.pyc
/opt/ros/kinetic/lib/pkgconfig
/opt/ros/kinetic/lib/pkgconfig/catkin.pc
/opt/ros/kinetic/etc
/opt/ros/kinetic/etc/catkin
/opt/ros/kinetic/etc/catkin/profile.d
/opt/ros/kinetic/etc/catkin/profile.d/05.catkin_make.bash
/opt/ros/kinetic/etc/catkin/profile.d/05.catkin_make_isolated.bash
/opt/ros/kinetic/share
/opt/ros/kinetic/share/catkin
/opt/ros/kinetic/share/catkin/cmake
/opt/ros/kinetic/share/catkin/cmake/catkin_python_setup.cmake
/opt/ros/kinetic/share/catkin/cmake/stamp.cmake
/opt/ros/kinetic/share/catkin/cmake/safe_execute_process.cmake
/opt/ros/kinetic/share/catkin/cmake/all.cmake
/opt/ros/kinetic/share/catkin/cmake/debug_message.cmake
/opt/ros/kinetic/share/catkin/cmake/shell.cmake
/opt/ros/kinetic/share/catkin/cmake/list_insert_in_workspace_order.cmake
/opt/ros/kinetic/share/catkin/cmake/catkin_package_xml.cmake
/opt/ros/kinetic/share/catkin/cmake/templates
/opt/ros/kinetic/share/catkin/cmake/templates/setup.zsh.in
/opt/ros/kinetic/share/catkin/cmake/templates/env.sh.in
/opt/ros/kinetic/share/catkin/cmake/templates/rosinstall.in
/opt/ros/kinetic/share/catkin/cmake/templates/env-hook.context.py.in
/opt/ros/kinetic/share/catkin/cmake/templates/script.sh.in
/opt/ros/kinetic/share/catkin/cmake/templates/relay.py.in
/opt/ros/kinetic/share/catkin/cmake/templates/setup.bat.in
/opt/ros/kinetic/share/catkin/cmake/templates/Doxyfile.in
/opt/ros/kinetic/share/catkin/cmake/templates/script.bash.in
/opt/ros/kinetic/share/catkin/cmake/templates/env.bat.in
/opt/ros/kinetic/share/catkin/cmake/templates/safe_execute_install.cmake.in
/opt/ros/kinetic/share/catkin/cmake/templates/script.in
/opt/ros/kinetic/share/catkin/cmake/templates/script.py.in
/opt/ros/kinetic/share/catkin/cmake/templates/_setup_util.py.in
/opt/ros/kinetic/share/catkin/cmake/templates/setup.bash.in
/opt/ros/kinetic/share/catkin/cmake/templates/pkgConfig.cmake.in
/opt/ros/kinetic/share/catkin/cmake/templates/python_distutils_install.sh.in
/opt/ros/kinetic/share/catkin/cmake/templates/setup.sh.in
/opt/ros/kinetic/share/catkin/cmake/templates/__init__.py.in
/opt/ros/kinetic/share/catkin/cmake/templates/python_distutils_install.bat.in
/opt/ros/kinetic/share/catkin/cmake/templates/cfg-extras.context.py.in
/opt/ros/kinetic/share/catkin/cmake/templates/generate_cached_setup.py.in
/opt/ros/kinetic/share/catkin/cmake/templates/pkg.context.pc.in
/opt/ros/kinetic/share/catkin/cmake/templates/pkgConfig-version.cmake.in
/opt/ros/kinetic/share/catkin/cmake/templates/order_packages.context.py.in
/opt/ros/kinetic/share/catkin/cmake/em
/opt/ros/kinetic/share/catkin/cmake/em/order_packages.cmake.em
/opt/ros/kinetic/share/catkin/cmake/em/pkg.pc.em
/opt/ros/kinetic/share/catkin/cmake/platform
/opt/ros/kinetic/share/catkin/cmake/platform/lsb.cmake
/opt/ros/kinetic/share/catkin/cmake/platform/windows.cmake
/opt/ros/kinetic/share/catkin/cmake/platform/ubuntu.cmake
/opt/ros/kinetic/share/catkin/cmake/catkin_package.cmake
/opt/ros/kinetic/share/catkin/cmake/catkin_workspace.cmake
/opt/ros/kinetic/share/catkin/cmake/catkin_add_env_hooks.cmake
/opt/ros/kinetic/share/catkin/cmake/list_append_deduplicate.cmake
/opt/ros/kinetic/share/catkin/cmake/env-hooks
/opt/ros/kinetic/share/catkin/cmake/env-hooks/05.catkin_make.bash
/opt/ros/kinetic/share/catkin/cmake/env-hooks/05.catkin_make_isolated.bash
/opt/ros/kinetic/share/catkin/cmake/assert.cmake
/opt/ros/kinetic/share/catkin/cmake/string_starts_with.cmake
/opt/ros/kinetic/share/catkin/cmake/empy.cmake
/opt/ros/kinetic/share/catkin/cmake/catkin_download.cmake
/opt/ros/kinetic/share/catkin/cmake/python.cmake
/opt/ros/kinetic/share/catkin/cmake/interrogate_setup_dot_py.py
/opt/ros/kinetic/share/catkin/cmake/test
/opt/ros/kinetic/share/catkin/cmake/test/tests.cmake
/opt/ros/kinetic/share/catkin/cmake/test/catkin_download_test_data.cmake
/opt/ros/kinetic/share/catkin/cmake/test/download_checkmd5.py
/opt/ros/kinetic/share/catkin/cmake/test/run_tests.py
/opt/ros/kinetic/share/catkin/cmake/test/nosetests.cmake
/opt/ros/kinetic/share/catkin/cmake/test/remove_test_results.py
/opt/ros/kinetic/share/catkin/cmake/test/gtest.cmake
/opt/ros/kinetic/share/catkin/cmake/list_append_unique.cmake
/opt/ros/kinetic/share/catkin/cmake/find_program_required.cmake
/opt/ros/kinetic/share/catkin/cmake/catkin_libraries.cmake
/opt/ros/kinetic/share/catkin/cmake/catkin_install_python.cmake
/opt/ros/kinetic/share/catkin/cmake/catkinConfig-version.cmake
/opt/ros/kinetic/share/catkin/cmake/tools
/opt/ros/kinetic/share/catkin/cmake/tools/rt.cmake
/opt/ros/kinetic/share/catkin/cmake/tools/bz2.cmake
/opt/ros/kinetic/share/catkin/cmake/tools/threads.cmake
/opt/ros/kinetic/share/catkin/cmake/tools/libraries.cmake
/opt/ros/kinetic/share/catkin/cmake/tools/doxygen.cmake
/opt/ros/kinetic/share/catkin/cmake/catkin_generate_environment.cmake
/opt/ros/kinetic/share/catkin/cmake/catkinConfig.cmake
/opt/ros/kinetic/share/catkin/cmake/catkin_destinations.cmake
/opt/ros/kinetic/share/catkin/cmake/catkin_metapackage.cmake
/opt/ros/kinetic/share/catkin/cmake/parse_package_xml.py
/opt/ros/kinetic/share/catkin/cmake/legacy.cmake
/opt/ros/kinetic/share/catkin/cmake/toplevel.cmake
/opt/ros/kinetic/share/catkin/cmake/em_expand.cmake
/opt/ros/kinetic/share/catkin/cmake/order_paths.py
/opt/ros/kinetic/share/catkin/cmake/atomic_configure_file.cmake
/opt/ros/kinetic/share/catkin/LICENSE
/opt/ros/kinetic/share/catkin/package.xml
/opt/ros/kinetic/env.sh
/opt/ros/kinetic/.rosinstall
/opt/ros/kinetic/setup.sh
/opt/ros/kinetic/bin
/opt/ros/kinetic/bin/catkin_topological_order
/opt/ros/kinetic/bin/catkin_package_version
/opt/ros/kinetic/bin/catkin_test_results
/opt/ros/kinetic/bin/catkin_make_isolated
/opt/ros/kinetic/bin/catkin_prepare_release
/opt/ros/kinetic/bin/catkin_find
/opt/ros/kinetic/bin/catkin_init_workspace
/opt/ros/kinetic/setup.zsh
/opt/ros/kinetic/_setup_util.py
/opt/ros/kinetic/.catkin
/usr
/usr/share
/usr/share/doc
/usr/share/doc/ros-kinetic-catkin
/usr/share/doc/ros-kinetic-catkin/changelog.Debian.gz
dpkg -L python-catkin-pkg-modules yields:
/usr
/usr/share
/usr/share/doc
/usr/share/doc/python-catkin-pkg-modules
/usr/share/doc/python-catkin-pkg-modules/copyright
/usr/share/doc/python-catkin-pkg-modules/changelog.Debian.gz
/usr/lib
/usr/lib/python2.7
/usr/lib/python2.7/dist-packages/catkin_pkg_modules-0.4.6.egg-info
/usr/lib/python2.7/dist-packages/catkin_pkg_modules-0.4.6.egg-info/top_level.txt
/usr/lib/python2.7/dist-packages/catkin_pkg_modules-0.4.6.egg-info/dependency_links.txt
/usr/lib/python2.7/dist-packages/catkin_pkg_modules-0.4.6.egg-info/PKG-INFO
/usr/lib/python2.7/dist-packages/catkin_pkg_modules-0.4.6.egg-info/requires.txt
/usr/lib/python2.7/dist-packages/catkin_pkg/topological_order.py
/usr/lib/python2.7/dist-packages/catkin_pkg/metapackage.py
/usr/lib/python2.7/dist-packages/catkin_pkg/tool_detection.py
/usr/lib/python2.7/dist-packages/catkin_pkg/terminal_color.py
/usr/lib/python2.7/dist-packages/catkin_pkg/changelog_generator.py
/usr/lib/python2.7/dist-packages/catkin_pkg/__init__.py
/usr/lib/python2.7/dist-packages/catkin_pkg/cmake.py
/usr/lib/python2.7/dist-packages/catkin_pkg/changelog_generator_vcs.py
/usr/lib/python2.7/dist-packages/catkin_pkg/templates
/usr/lib/python2.7/dist-packages/catkin_pkg/templates/CMakeLists.txt.in
/usr/lib/python2.7/dist-packages/catkin_pkg/templates/package.xml.in
/usr/lib/python2.7/dist-packages/catkin_pkg/templates/metapackage.cmake.in
/usr/lib/python2.7/dist-packages/catkin_pkg/python_setup.py
/usr/lib/python2.7/dist-packages/catkin_pkg/group_dependency.py
/usr/lib/python2.7/dist-packages/catkin_pkg/package_templates.py
/usr/lib/python2.7/dist-packages/catkin_pkg/workspace_vcs.py
/usr/lib/python2.7/dist-packages/catkin_pkg/package.py
/usr/lib/python2.7/dist-packages/catkin_pkg/group_membership.py
/usr/lib/python2.7/dist-packages/catkin_pkg/packages.py
/usr/lib/python2.7/dist-packages/catkin_pkg/changelog.py
/usr/lib/python2.7/dist-packages/catkin_pkg/cli
/usr/lib/python2.7/dist-packages/catkin_pkg/cli/prepare_release.py
/usr/lib/python2.7/dist-packages/catkin_pkg/cli/create_pkg.py
/usr/lib/python2.7/dist-packages/catkin_pkg/cli/test_changelog.py
/usr/lib/python2.7/dist-packages/catkin_pkg/cli/generate_changelog.py
/usr/lib/python2.7/dist-packages/catkin_pkg/cli/tag_changelog.py
/usr/lib/python2.7/dist-packages/catkin_pkg/cli/__init__.py
/usr/lib/python2.7/dist-packages/catkin_pkg/cli/find_pkg.py
/usr/lib/python2.7/dist-packages/catkin_pkg/cli/package_version.py
/usr/lib/python2.7/dist-packages/catkin_pkg/package_version.py
/usr/lib/python2.7/dist-packages/catkin_pkg/condition.py
/usr/lib/python2.7/dist-packages/catkin_pkg/rospack.py
/usr/lib/python2.7/dist-packages/catkin_pkg/workspaces.py
which python yields:
/usr/bin/python
on Python 2.7.12
echo $PYTHONPATH yields:
/opt/ros/kinetic/lib/python2.7/dist-packages:/home/achille/.local/lib/python2.7/site-packages:/home/achille/.local/lib/python2.7/site-packages:/opt/ros/kinetic/bin:/home/achille/.local/lib/python2.7/site-packages:/usr/lib/python2.7/dist-packages
echo $PATH yields:
/opt/ros/kinetic/bin:/home/achille/bin:/home/achille/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
python -c "import sys; print(sys.path)" yields:
['', '/opt/ros/kinetic/lib/python2.7/dist-packages', '/home/achille/.local/lib/python2.7/site-packages', '/usr/lib/python2.7/dist-packages', '/usr/lib/python2.7', '/usr/lib/python2.7/plat-x86_64-linux-gnu', '/usr/lib/python2.7/lib-tk', '/usr/lib/python2.7/lib-old', '/usr/lib/python2.7/lib-dynload', '/usr/local/lib/python2.7/dist-packages', '/usr/local/lib/python2.7/dist-packages/sklearn-0.0-py2.7.egg', '/usr/local/lib/python2.7/dist-packages/scikit_learn-0.19.1-py2.7-linux-x86_64.egg', '/usr/local/lib/python2.7/dist-packages/joblib-0.12.0-py2.7.egg', '/usr/local/lib/python2.7/dist-packages/setproctitle-1.1.10-py2.7-linux-x86_64.egg', '/usr/local/lib/python2.7/dist-packages/multiprocess-0.70.6.1-py2.7-linux-x86_64.egg', '/usr/local/lib/python2.7/dist-packages/ruamel.yaml-0.15.41-py2.7-linux-x86_64.egg', '/usr/local/lib/python2.7/dist-packages/dill-0.2.8.2-py2.7.egg', '/usr/local/lib/python2.7/dist-packages/ruamel.ordereddict-0.4.13-py2.7-linux-x86_64.egg', '/usr/local/lib/python2.7/dist-packages/trimesh-2.31.9-py2.7.egg', '/usr/local/lib/python2.7/dist-packages/imageio-2.3.0-py2.7.egg', '/usr/local/lib/python2.7/dist-packages/h5py-2.8.0-py2.7-linux-x86_64.egg', '/usr/local/lib/python2.7/dist-packages/cvxopt-1.2.0-py2.7-linux-x86_64.egg', '/usr/local/lib/python2.7/dist-packages/scikit_video-1.1.10-py2.7.egg', '/usr/local/lib/python2.7/dist-packages/scikit_image-0.14.0-py2.7-linux-x86_64.egg', '/usr/local/lib/python2.7/dist-packages/ipython-5.5.0-py2.7.egg', '/usr/local/lib/python2.7/dist-packages/pyserial-3.4-py2.7.egg', '/usr/local/lib/python2.7/dist-packages/opencv_python-3.4.1.15-py2.7-linux-x86_64.egg', '/usr/local/lib/python2.7/dist-packages/dask-0.18.1-py2.7.egg', '/usr/local/lib/python2.7/dist-packages/cloudpickle-0.5.3-py2.7.egg', '/usr/local/lib/python2.7/dist-packages/pyglet-1.4.0a1-py2.7.egg', '/usr/local/lib/python2.7/dist-packages/PyOpenGL-3.1.0-py2.7.egg', '/usr/local/lib/python2.7/dist-packages/PyOpenGL_accelerate-3.1.0-py2.7-linux-x86_64.egg', '/usr/local/lib/python2.7/dist-packages/colorlog-3.1.4-py2.7.egg', '/usr/local/lib/python2.7/dist-packages/msgpack-0.5.6-py2.7-linux-x86_64.egg', '/usr/local/lib/python2.7/dist-packages/sympy-1.1.1-py2.7.egg', '/usr/local/lib/python2.7/dist-packages/svg.path-2.2-py2.7.egg', '/usr/local/lib/python2.7/dist-packages/Rtree-0.8.3-py2.7.egg', '/usr/local/lib/python2.7/dist-packages/Shapely-1.6.4.post1-py2.7-linux-x86_64.egg', '/usr/local/lib/python2.7/dist-packages/future-0.16.0-py2.7.egg', '/usr/local/lib/python2.7/dist-packages/PyWavelets-0.5.2-py2.7-linux-x86_64.egg', '/usr/local/lib/python2.7/dist-packages/traitlets-4.3.2-py2.7.egg', '/usr/local/lib/python2.7/dist-packages/simplegeneric-0.8.1-py2.7.egg', '/usr/local/lib/python2.7/dist-packages/prompt_toolkit-1.0.15-py2.7.egg', '/usr/local/lib/python2.7/dist-packages/pickleshare-0.7.4-py2.7.egg', '/usr/local/lib/python2.7/dist-packages/pexpect-4.6.0-py2.7.egg', '/usr/local/lib/python2.7/dist-packages/pathlib2-2.3.2-py2.7.egg', '/usr/local/lib/python2.7/dist-packages/backports.shutil_get_terminal_size-1.0.0-py2.7.egg', '/usr/local/lib/python2.7/dist-packages/mpmath-1.0.0-py2.7.egg', '/home/achille/Documents/peanut_robotics/dexnet_ws/src/meshpy', '/home/achille/Documents/peanut_robotics/dexnet_ws/src/dex-net/src', '/usr/lib/python2.7/dist-packages/PILcompat', '/usr/lib/python2.7/dist-packages/gtk-2.0', '/usr/lib/python2.7/dist-packages/wx-3.0-gtk2']
Originally posted by achille on ROS Answers with karma: 464 on 2018-07-06
Comment by Dirk Thomas on 2018-07-06:
What version of the modules do you have installed? dpkg -L python-catkin-pkg-modules
Comment by achille on 2018-07-06:
Updated the question with that output: 0.4.6
And where is the catkin_pkg module being found? python -c "import catkin_pkg; print(catkin_pkg.__file__)"
That command is the one that's not working: ImportError: No module named catkin_pkg. I tried all instructions in related questions.
Can you share the search path: python -c "import sys; print(sys.path)"
updated the question
Please try to unset the PYTHONPATH by invoking unset PYTHONPATH. Then try python -c "import catkin_pkg; print(catkin_pkg.__file__)" and python -c "import sys; print(sys.path)" again.
The import still fails, even after restarting the terminal. sys.path does contain /usr/lib/python2.7/dist-packages now though.
sys.path already contained /usr/lib/python2.7/dist-packages before. Are there any other paths before that one now? If yes, please check there content since they might interfere with the lookup.
You're right, missed that in the diff. Now most packages come before that one in the list. What should I be checking for? Can or should I reset this list? Should I explicitly add this line to the beginning of PYTHONPATH?
I added it to the front of the list through PYTHONPATH so that it's first (after '') in the list. The import still errors.
Comment by sloretz on 2018-07-10:
What's the output of import catkin_pkg, and if that works, what's the output of import inspect; inspect.getsourcefile(catkin_pkg) ?
Also, what's the output of import imp; imp.find_module('catkin_pkg') ?
Comment by achille on 2018-07-10:
As I mentioned above, import catkin_pkg only works when I do pip install catkin_pkg. When I do that, I get ``/home/achille/.local/lib/python2.7/site-packages/catkin_pkgfor bothimpandinspect`. Without the pip install, obviously neither works.
Any change in behavior after reinstalling python-catkin-pkg-modules? sudo apt install --reinstall python-catkin-pkg-modules
Not sure why or how but that did it! Please do add it as the answer to this question.
I don't know the cause, but happy to hear the problem went away after running sudo apt install --reinstall python-catkin-pkg-modules.
Originally posted by sloretz with karma: 3061 on 2018-07-11
