following is the snipet of my code i want to change the frequency with which the image is pubished i tried changing the loop_rate(10) to loop_rate(1) but it didn't work
    ros::Rate loop_rate(10);
    int counter =0;
       while(ros::ok() ){
    counter++;
        #if 1
            ros::Time time = ros::Time::now();
            cv_ptr->encoding = "bgr8";
            cv_ptr->header.stamp = time;
cv_ptr->header.frame_id = "/Sufyan_ImageTopic";
        #endif
            cv_ptr->image = image;
            image_pub_.publish(cv_ptr->toImageMsg());
            ROS_INFO("ImageMsg Send.");
        #endif
    ros::spin();
Originally posted by Sufyan on ROS Answers with karma: 17 on 2018-09-23
Hi you must to use loop_rate.sleep() in the end of while to control your loop rate
           while(ros::ok() ){
               counter++;
#if 1
 #endif
#endif
                loop_rate.sleep();
Originally posted by Hamid Didari with karma: 1769 on 2018-09-23
