The motoman_driver tutorial left me hanging after these lines. How would I know if the pseudo-external signal is successful?
Rotate the pendant key-switch (upper left of pendant) fully counter-clockwise into TEACH mode.
Upgrade your Security Level to MANAGEMENT
Using the pendant, select [In/OUT]→[PSEUDO INPUT SIG]
Set input #82015 CMD REMOTE SEL to ON
Rotate the pendant key-switch (upper left of pendant) fully clockwise into REMOTE mode.
Thanks! I'm referring to this page: http://wiki.ros.org/motoman_driver/Tutorials/indigo/InstallServer
Originally posted by AndyZe on ROS Answers with karma: 2331 on 2018-09-07
Comment by gvdhoorn on 2018-09-07:
You tagged this with HC10
Please see Compatibility with collaborative robots (HC series). Afaik, MotoROS is as yet not compatible with the collaborative robots of Yaskawa.
Comment by AndyZe on 2018-09-07:
I was hoping the next line implied it would work if the Power/Force-Limiting features were disabled:
The MotoROS application can be installed, but only after disabling the collaborative features
It's fine if it won't work, but we would rather use ROS ;)
Yes, that is stated in that section, but last time I spoke to @millete he said it was not supported at all at the moment.
Perhaps he can clarify.
Edit: and we should update the docs.
Reported: ros-industrial/motoman/issues/243.
I got a strong no on HC10 compatability from Motoman. Will edit the docs.
Comment by gvdhoorn on 2018-09-08:
Your actual question has of course still not been addressed.
Perhaps @millete can answer that one as well :)
Comment by millete on 2018-09-10:
HC10 is not compatible today. But we have a team actively working on it now.
