I am trying to integrate a new custom gripper to the tiago robot from pal robotics in ros indigo environment. I am using the gripper_action_controller (link text) from ros_controllers to make the gripper work. The transmission of the gripper is set as:
<joint name="${name}_joint" >
    <hardwareInterface>hardware_interface/PositionJointInterface</hardwareInterface>
which is same in the hardware_interface _adapter.h of gripper_action_controller pkg. The {name} above is ¨gripper¨ , and i used the same to replace the joint name in the gripper-action-controller.h , wherever needed. Below are the configurations for gazebo and moveit.
   // controller_configuration_gazebo/controllers.yaml
    gripper_controller:
      type: "position_controllers/GripperActionController"
      check_mode: True
      joints:
        - gripper_joint
  //moveit
    - name: gripper_controller
        action_ns: "gripper_cmd"
        type: GripperCommand
        default: true
        joints:
           - gripper_joint
I have finished adding the gripper to the robot urdf, configure it to moveit and used kinematics test to confirm that the right gripper joint is configured and can be moved manually. when i launched the robot in gazebo, i encounter an error but the robot is launched with the new gripper.
[INFO] [WallTime: 1524051958.505068] [0.094000] Loading controller: mobile_base_controller
[FATAL] [1524051958.505654471, 0.095000000]: Failed to start controller in realtime loop. This should never happen.
[INFO] [WallTime: 1524051958.506842] [0.096000] Started controllers: gripper_controller
And when run rosservice call /controller_manager/list-controllers, i can observe that the gripper_controller is stopped and there is no hardware interface and resources allocated to the controller.
    state: stopped
    type: position_controllers/GripperActionController
    claimed_resources: []
I need help in finding why the hardware interface and resources are not connected and how they can be connected.
Originally posted by naveen010 on ROS Answers with karma: 16 on 2018-04-18
Since Tiago has the joint_trajectory_controller.yaml defining all joints in the controller_configuration_gazebo pkg; by adding a new yaml named as gripper_action_controller.yaml defining only gripper joint and loading it to rosparam in the launch file is solving all the issues shown above.
Originally posted by naveen010 with karma: 16 on 2018-04-24
