Using Unity and the RosSharp library I'm able to connect but unable to subscribe to any custom .msg types. The types are correctly named in the RosSharp dictionary and builds fine on the ROS side. After requesting to subscribe it will throw the error on the rosbridge socket terminal:
unable to load the manifest for package ####. Caused by ####
ROS path [0]=/opt/ros/kinetic/share/ros
ROS path [1]=/opt/ros/kinetic/share
Any thoughts?
Thanks, Lane
Originally posted by Lane on ROS Answers with karma: 3 on 2018-03-23
Comment by gvdhoorn on 2018-03-24:
Is package ### present in your workspace / installed on your system? Does rospack find #### return the expected output (in the same terminal as where you start the RosBridge nodes)? I don't see any Catkin workspace in the error output, so did you source it?
Comment by Lane on 2018-03-26:
the package is present, rospack find identifies it and i did source ./devel/setup.bash after the catkin_make.
Comment by Lane on 2018-03-27:
This works on a linux box, but fails on my VirtualBox VM - identical projects.
Just making sure: the terminal where you started rosbridge also had sourced the workspace setup.bash?
Edit:
Wow, did not realize that was required for each new terminal.
Yes, that is needed in every terminal. See #q286466 for a recent question about this.
Originally posted by gvdhoorn with karma: 86574 on 2018-03-27
Wow, did not realize that was required for each new terminal. Seems to be working fine, thanks =)
run source catkin_ws/devel/setup.bash in the bridge terminal window.
