I have ROS lunar from source running in notebook, while running any simulation with gazebo 8 I have this error message:
SpawnModel script started
[ INFO] [1510746273.283898971]: Loading freefloating_fluid plugin
[FATAL] [1510746273.284096302]: You must call ros::init() before creating the first NodeHandle
Couldn't find an AF_INET address for []
[ERROR] [1510746273.287385416]: [registerPublisher] Failed to contact master at [:0].  Retrying...
[INFO] [1510746273.304076, 0.000000]: Loading model XML from ros parameter
[INFO] [1510746273.309921, 0.000000]: Waiting for service /gazebo/spawn_urdf_model
[INFO] [1510746273.330882, 0.000000]: Loading model XML from ros parameter
[INFO] [1510746273.333284, 0.000000]: Waiting for service /gazebo/spawn_sdf_model
Any idea of how to solve it or how to debug it ?
I have /etc/hosts configured. And my env ros env are: export ROS_MASTER_URI=http://localhost:11311;export ROS_HOSTNAME=localhost
Originally posted by Patrickelectric on ROS Answers with karma: 1 on 2017-11-15
Comment by jayess on 2017-11-16:
Can you please update your question with the entire terminal output?
Hi @Patrickelectric ,
that happens because you have to call ros::init() BEFORE the instantiation of your ros::NodeHandle.
As an example, If you compile the code below (from Writing a Simple Publisher and Subscriber tutorial ), as is, it will work because ros::init is being called first. But if you uncomment the nodeBeforeRosInitWillFail node, you will see that this error happens since ros::init is called AFTER nodeBeforeRosInitWillFail.
#include "ros/ros.h"
#include "std_msgs/String.h"
#include <sstream>
   * Definining a ros::NodeHandle before ros::init causes the error
   * To confirm that, just uncomment the  nodeBeforeRosInitWillFail node below
  //ros::NodeHandle nodeBeforeRosInitWillFail;
  ros::init(argc, argv, "talker");
  ros::NodeHandle n;
  ros::Publisher chatter_pub = n.advertise<std_msgs::String>("chatter", 1000);
  ros::Rate loop_rate(10);
  int count = 0;
  while (ros::ok())
    std_msgs::String msg;
    std::stringstream ss;
    ss << "hello world " << count;
    msg.data = ss.str();
    ROS_INFO("%s", msg.data.c_str());
    chatter_pub.publish(msg);
    ros::spinOnce();
    loop_rate.sleep();
    ++count;
  return 0;
You can see this example in the following video (https://youtu.be/UsuQwUkzNII) if you prefer.
Originally posted by Ruben Alves with karma: 1038 on 2017-11-15
Comment by Patrickelectric on 2017-11-16:
I do not have a ros:init and a node, check my launcher https://pastebin.com/mywwMrDY
Comment by Ruben Alves on 2017-11-20:
Then this is the problem, @Patrickelectric. You have to call ros::initon your freefloating_fluid plugin.
Comment by Patrickelectric on 2017-11-23:
But the plugin have it. https://github.com/freefloating-gazebo/freefloating_gazebo/blob/master/src/freefloating_pids_main.cpp
