Dear All. while I try to Starting the Manipulation Pipeline. I just based on the following website: http://www.ros.org/wiki/pr2_tabletop_manipulation_apps/Tutorials/Starting%20the%20Manipulation%20Pipeline
The step is:
- rosmake pr2_tabletop_manipulation_launch
- roscore
- export ROBOT=sim
- roscd pr2_tabletop_manipulation_launch
- modify the pr2_tabletop_manipulation.launch just
Just make it connect as a client for object database running on remote server at Willow Garage 6 cd ~ 7. roslaunch pr2_tabletop_manipulation_launch pr2_tabletop_manipulation.launch The I got the following information: Mainly is said that :
[ERROR] [1329418027.455848865]: Robot model '/robot_description' not found! Did you remap 'robot_description'? [ WARN] [1329418027.463987029]: Models not loaded [FATAL] [1329418027.466372646]: Could not load the xml from parameter server: robot_description
[ERROR] [1329418027.466448443]: Could not load robot model. Are you sure the robot model is on the parameter server?
do I need more step to run this demo? I am using ubuntu 11.04 or 10.04, 64 bit electric ros. The problems are the same. Thanks for any help. Best regards. Zhenli
[ INFO] [1329418027.444594041]: waitForService: Service [/tabletop_object_recognition] has not been advertised, waiting... [ERROR] [1329418027.455848865]: Robot model '/robot_description' not found! Did you remap 'robot_description'? [ WARN] [1329418027.463987029]: Models not loaded [FATAL] [1329418027.466372646]: Could not load the xml from parameter server: robot_description
[ERROR] [1329418027.466448443]: Could not load robot model. Are you sure the robot model is on the parameter server? [collider_node-11] process has died [pid 22887, exit code -11]. log files: /home/administrator/.ros/log/ff64f9c2-58cb-11e1-953f-18f46a4fafa8/collider_node-11*.log respawning... [collider_node-11] restarting process process[collider_node-11]: started with pid [23024] [ INFO] [1329418027.750126583]: Waiting for environment server planning scene registration service /register_planning_scene [ INFO] [1329418027.751014430]: waitForService: Service [/register_planning_scene] has not been advertised, waiting... [FATAL] [1329418027.765071054]: Could not load the xml from parameter server: robot_description
[ERROR] [1329418027.765130414]: Could not load robot model. Are you sure the robot model is on the parameter server? [ INFO] [1329418027.850490364]: Waiting for environment server planning scene registration service /register_planning_scene [ INFO] [1329418027.857919089]: waitForService: Service [/register_planning_scene] has not been advertised, waiting... [ERROR] [1329418027.871698784]: Robot model '/robot_description' not found! Did you remap 'robot_description'? [ WARN] [1329418027.875139906]: Models not loaded [collider_node-11] process has died [pid 23024, exit code -11]. log files: /home/administrator/.ros/log/ff64f9c2-58cb-11e1-953f-18f46a4fafa8/collider_node-11*.log respawning... [collider_node-11] restarting process process[collider_node-11]: started with pid [23157] [FATAL] [1329418027.968994927]: Could not load the xml from parameter server: robot_description
[ERROR] [1329418027.969069875]: Could not load robot model. Are you sure the robot model is on the parameter server?
Originally posted by zhenli on ROS Answers with karma: 287 on 2012-02-16
