I am running a two bag files one runs fine the other produces an error:
[rgbdtam-3] process has died [pid 28773, exit code -6, cmd /home/rjn/catkin_ws/devel/lib/rgbdtam/rgbdtam /camera/rgb/image_color:=/xtion/rgb/image_raw /camera/depth/image:=/xtion/depth/image_raw __name:=rgbdtam __log:=/home/rjn/.ros/log/8047b868-c1a3-11e7-9b8b-0028f87b9f9e/rgbdtam-3.log].
log file: /home/rjn/.ros/log/8047b868-c1a3-11e7-9b8b-0028f87b9f9e/rgbdtam-3*.log
The bag file producing the error has its depth image as 16UC1 and the other bag has 32FC1. I am assuming that is is what is causing the error as there are only image and depth messages in the bag files nothing else.
I tried using dbg to catch the stack trace but it does not produce one.
Does anyone know how to capture the or issue a stack trace form dbg?
thank you.
Here is output of gdb window. note line number reference given....thanks for help.
V Thread 15 "rgbdtam" received signal SIGABRT, Aborted.
[Switching to Thread 0x7fffc4b4f700 (LWP 30105)]
0x00007fffed2ff428 in __GI_raise (sig=sig@entry=6)
at ../sysdeps/unix/sysv/linux/raise.c:54
54 ../sysdeps/unix/sysv/linux/raise.c: No such file or directory.
(gdb) bt
#0 0x00007fffed2ff428 in __GI_raise (sig=sig@entry=6)
#1 0x00007fffed30102a in __GI_abort () at abort.c:89
#2 0x00007fffedb5b84d in __gnu_cxx::__verbose_terminate_handler() ()
from /usr/lib/x86_64-linux-gnu/libstdc++.so.6
#3 0x00007fffedb596b6 in ?? () from /usr/lib/x86_64-linux-gnu/libstdc++.so.6
#4 0x00007fffedb59701 in std::terminate() ()
#5 0x00007fffedb59919 in __cxa_throw ()
#6 0x00007ffff6843cf2 in cv::error(cv::Exception const&) ()
from /opt/ros/kinetic/lib/libopencv_core3.so.3.2
#7 0x00007ffff6843e83 in cv::error(int, cv::String const&, char const*, char const*, int) () from /opt/ros/kinetic/lib/libopencv_core3.so.3.2
#8 0x00007ffff68e7c9a in cv::_OutputArray::create(int, int, int, int, bool, int) const () from /opt/ros/kinetic/lib/libopencv_core3.so.3.2
#9 0x00007ffff6838eb9 in cv::Mat::copyTo(cv::_OutputArray const&) const ()
#10 0x000000000047a3c0 in resize_points (points2=..., points=...,
reduction=<optimized out>, image_p=...,
kinect_initialization=kinect_initialization@entry=1,
limit_grad=limit_grad@entry=1)
at /home/rjn/catkin_ws/src/rgbdtam/src/SemiDenseTracking.cpp:1899
---Type <return> to continue, or q <return> to quit---
Originally posted by rnunziata on ROS Answers with karma: 713 on 2017-11-04
