Hi , I want to commicate this arduino code with ROS. How can I do this ? Please help me ?
#include <Wire.h>
#define MD22ADDRESS 0x58
#define SOFTREG 0x07
#define MOTOR1 0x01
#define ACCELLREG 0x03
signed long int pulse=0;
unsigned long last_time;
int ang=0;
int encoder_a=2;
int encoder_b=3;
float encoder_resolution=1024;
void setup()
Wire.begin();
delay(100);
Serial.begin(115200);
attachInterrupt(0,encoder_kesme_a,CHANGE);
last_time=millis();
setMode();
void loop()
delay(10);
Wire.beginTransmission(MD22ADDRESS);
Wire.write(MOTOR1);
Wire.write(220);
Wire.endTransmission();
if(millis()-last_time>1000)
ang=((pulse/encoder_resolution)*360.0);
ang=int(ang)%360;
Serial.println("Dc Motor Angle : " +String(ang));
last_time=millis();
void setMode(){
Wire.write(ACCELLREG);
Wire.write(0xFF);
void encoder_kesme_a()
if (digitalRead(encoder_a) == HIGH)
if (digitalRead(encoder_b) == HIGH)
pulse++ ;
else
pulse = pulse - 1;
else
pulse = pulse - 1;
else
pulse++;
Originally posted by Mekateng on ROS Answers with karma: 85 on 2017-10-15
Post score: -1
Comment by NEngelhard on 2017-10-15:
Please add what you tried so far. Your post does not show any attempt of you to solve the task yourself. answers.ros is about helping, not doing it for you.
Comment by Mekateng on 2017-10-15:
I converted 2d laserscan to 3d pointcloud and ı want to use dc motor with encoder to angle data instead of dynamixel servo motor . So ı wrote an arduino code that obtain an angle data. But I don't know how to communicate this code with the ROS. How to make the edits on this code.
