This question is related to one I posted earlier: http://answers.ros.org/question/265135/moveit-using-solve-type-speed-instead-of-distance/. MoveIt! currently launches correctly with solve_type: Distance, which is the solve type I want. However, when I run a Python script to issue move commands, it still uses solve_type: Speed:
[ INFO] [1499261352.380466647]: Looking in private handle: /move_group_commander_wrappers_1499261351880510562 for param name: manipulator/position_only_ik
[ INFO] [1499261352.381577584]: Looking in private handle: /move_group_commander_wrappers_1499261351880510562 for param name: manipulator/solve_type
[ INFO] [1499261352.382617524]: Using solve type Speed
The code I use to set up my node comes from the tutorial: http://docs.ros.org/hydro/api/pr2_moveit_tutorials/html/planning/scripts/doc/move_group_python_interface_tutorial.html.
How would I guarantee the solve_type used when running my code is the type I want? The first idea that comes to mind is changing where it looks for the parameter manipulator/solve_type
, but I'm not sure how to do that.
Originally posted by cvancleef on ROS Answers with karma: 24 on 2017-07-05
