I switched to using trac_ik for my kinematics plugin and set the solve type to distance. Here's my kinematics.yaml
manipulator:
  kinematics_solver: trac_ik_kinematics_plugin/TRAC_IKKinematicsPlugin
  solve_type: Distance
  kinematics_solver_search_resolution: 0.002
  kinematics_solver_timeout: 0.1
  kinematics_solver_attempts: 300
However, when I launch MoveIt I get the following messages:
[ INFO] [1498738699.604294668]: Looking in private handle: /move_group_commander_wrappers_1498738699102337314 for param name: manipulator/solve_type
[ INFO] [1498738699.605287670]: Using solve type Speed
Am I setting the solve type incorrectly for use in MoveIt?
EDIT: I added
 <group ns="move_group">
    <rosparam command="load" file="$(find PACKAGE_NAME)/config/kinematics.yaml"/>
  </group>
to the start of my move_group.launch file. MoveIt! now displays the correct solve type on launch, but when I run code to move my robot, the terminal running my code still says its using solve type Speed.
[ INFO] [1498748362.955713863]: Looking in private handle: /move_group_commander_wrappers_1498748362452794445 for param name: manipulator/position_only_ik
[ INFO] [1498748362.960244821]: Looking in private handle: /move_group_commander_wrappers_1498748362452794445 for param name: manipulator/solve_type
[ INFO] [1498748362.961557738]: Using solve type Speed
Originally posted by cvancleef on ROS Answers with karma: 24 on 2017-06-29
This is a bug in where parameters are expected to be by MoveIt and the plugins. Have a look at this issue for details and a workaround:
https://github.com/ros-planning/moveit_ros/issues/629#issuecomment-282573234
A proper fix for upstream MoveIt would be highly appreciated! :)
Originally posted by v4hn with karma: 2950 on 2017-06-29
Comment by cvancleef on 2017-06-29:
I edited my question, do I need to change some other files to get this to work with my code?
It's slightly inconvenient, but IK plugins tend to search for their parameters in the namespace of the process (ie: node) that is hosting them. In the case of MoveIt Commander, that would be move_group_commander_wrappers_1498738699102337314.
But simply putting it in that namespace won't do: you probably have three instances of trac_ik hosted:
  1. in move_group (this is MoveIt 'proper')
  2. in rviz (for the MoveIt RViz plugin)
  3. in moveit_commander
I'm not sure (as I wasn't around when this was designed) but I think that is because of efficiency reasons (ie: avoid having to call an IK solver over a ROS service, which adds overhead to every call). But to get consistent behaviour, it'd be important to make sure all instances get the same parameters.
See traclabs/trac_ik#25 for a related issue.
Originally posted by gvdhoorn with karma: 86574 on 2017-06-29
