Hi, I was planning a pose for a 5-dof manipulator tip with moveit kdl solver. The position of the pose is reached, but the orientation cannot be reached. And the following warning is shown every time:
[ INFO] [1488121271.999191010, 373.663000000]: Planning request received for MoveGroup action. Forwarding to planning pipeline.
[ WARN] [1488121271.999485048, 373.663000000]: Orientation constraint for link 'tip' is probably incorrect: 0.000000, 0.000000, 1.000000, 0.500000. Assuming identity instead.
[ WARN] [1488121271.999603296, 373.663000000]: Orientation constraint for link 'tip' is probably incorrect: 0.000000, 0.000000, 1.000000, 0.500000. Assuming identity instead.
[ INFO] [1488121271.999718045, 373.663000000]: No optimization objective specified, defaulting to PathLengthOptimizationObjective
[ INFO] [1488121271.999857147, 373.663000000]: LBKPIECE1: Starting planning with 1 states already in datastructure
[ INFO] [1488121272.444189499, 374.101000000]: LBKPIECE1: Created 38 (20 start + 18 goal) states in 37 cells (19 start (19 on boundary) + 18 goal (18 on boundary))
[ INFO] [1488121272.444250950, 374.101000000]: Solution found in 0.444438 seconds
[ INFO] [1488121272.467475751, 374.124000000]: SimpleSetup: Path simplification took 0.000019 seconds and changed from 23 to 2 states
[ INFO] [1488121272.500154361, 374.156000000]: Combined planning and execution request received for MoveGroup action. Forwarding to planning and execution pipeline.
[ WARN] [1488121272.500245398, 374.156000000]: Orientation constraint for link 'tip' is probably incorrect: 0.000000, 0.000000, 1.000000, 0.500000. Assuming identity instead.
[ INFO] [1488121272.500362095, 374.156000000]: Planning attempt 1 of at most 1
[ WARN] [1488121272.500788898, 374.157000000]: Orientation constraint for link 'tip' is probably incorrect: 0.000000, 0.000000, 1.000000, 0.500000. Assuming identity instead.
[ WARN] [1488121272.500939599, 374.157000000]: Orientation constraint for link 'tip' is probably incorrect: 0.000000, 0.000000, 1.000000, 0.500000. Assuming identity instead.
[ INFO] [1488121272.501062772, 374.157000000]: No optimization objective specified, defaulting to PathLengthOptimizationObjective
[ INFO] [1488121272.501254698, 374.157000000]: LBKPIECE1: Starting planning with 1 states already in datastructure
[ INFO] [1488121273.689715240, 375.327000000]: LBKPIECE1: Created 75 (37 start + 38 goal) states in 74 cells (37 start (37 on boundary) + 37 goal (37 on boundary))
[ INFO] [1488121273.690050718, 375.327000000]: Solution found in 1.188844 seconds
[ INFO] [1488121273.700934373, 375.345000000]: SimpleSetup: Path simplification took 0.000024 seconds and changed from 66 to 2 states
[ WARN] [1488121273.702429142, 375.345000000]: Dropping first 1 trajectory point(s) out of 10, as they occur before the current time.
First valid point will be reached in 0.060s.
Does anybody have any idea what is wrong, please?
Originally posted by yangtfu on ROS Answers with karma: 11 on 2017-02-26
