This is not related to the local planners directly but to the local costmap setup (costmap_2d).
Local planners in the navigation stack have only access to the local costmap, so you need to add the desired layer
to the configuration.
Based on the Robot Setup and Configure and run Robot Navigation
Tutorial you might try the following:
E.g. in local_costmap_params.yaml
(or similar):
rolling_window: true
width: 5.0
height: 5.0
resolution: 0.1
plugins:
## Without proximity sensors, we do not need any obstacle_layer:
# - {name: obstacle_layer, type: "costmap_2d::VoxelLayer"}
## Static Layer
- {name: static_layer, type: "costmap_2d::StaticLayer"}
# Uncomment the following line if you want to inflate occupied cells
#- {name: inflation_layer, type: "costmap_2d::InflationLayer"}
Note, you might add more configurations for layers (inflation_layer and static_layer) either here or in the costmap_common_params.yaml
. Please check the costmap_2d documentation (static_map topic name, service, ...).
Notice, there was an issue early 2015 (see here) but it seems to be fixed according to the related merge requests on github. If it still does not work,
Originally posted by croesmann with karma: 2531 on 2017-02-21
Comment by geetam on 2017-02-21:
Thanks a lot for replying, The robot gets stuck when I add a static layer (even where there are no obstacles), teb_local_planner repeatedly prints "Trajectory is not feasible", I will read costmap_2d_documentation more carefully and will comment here again if it works.
ROS Version: Indigo.
Comment by croesmann on 2017-02-21:
The teb_local_planer prints this message if a collision with the current robot footprint (also specified in the costmap parameters) is detected. Did you configure the footprint correctly and did you also try dwa_local_planner with the static layer (to check if it is a bug)?
I don't think it is a bug in teb_local_planner as robot gets stuck even when dwa is used, value of robot_footprint: [[-0.11, -0.01], [0.11, -0.01], [-0.11, 0.2], [0.11, 0.2] ]
dwa prints warning "off map " with two floating point values. Can I post my yamls here?
