HI there,
I'm trying to use the Morse simulation but find some problems while run the tutorial"examples/tutorials/tutorial-1-ros.py". The error is as follow:
[helpers.loading] Module not found: No module named 'morse.middleware.ros_request_manager'
[helpers.loading] Could not load the class RosRequestManager in morse.middleware.ros_request_manager
[helpers.loading] Could not create an instance of morse.middleware.ros_request_manager.RosRequestManager
[core.services] Request Manager morse.middleware.ros_request_manager.RosRequestManager not found. Check for typos in the configuration file!
I've already installed the python3.4 and other elements which tutorials indicates. link text
And also refered the answer: link text But still cannot solve the problem.
Any ideas of this problem?
Originally posted by jiangqueque on ROS Answers with karma: 1 on 2016-12-28
Comment by gvdhoorn on 2016-12-28:
This would really seem to be a problem with Morse and one of its plugins, would you agree? I would suggest you ask this question on a Morse support forum, as you stand a much better chance of getting (good) answers.
