Hello, I don't know why this is happening but I've posted the terminal output below. I'm running Xubuntu 12.04 desktop inside VirtualBox. I've enabled 3D acceleration in the VM settings? Blender tries to start but then the screen just becomes garbled/distorted? Roscore appears to start without any problems. Any ideas or thoughts are greatly appreciated. Also, I apologize in advance if this is the wrong forum for this question but I couldn't find anything similar for blender or morse. Thanks.
mybox@mybox-VirtualBox:~$ morse run ros_example.py
morse 0.5.2
Copyright LAAS-CNRS 2011
AL lib: pulseaudio.c:331: PulseAudio returned minreq > tlength/2; expect break up connect failed: No such file or directory
ndof: spacenavd not found
OpenGL Warning: No pincher, please call crStateSetCurrentPointers() in your SPU
found bundled python: /home/mybox/builds/blender-2.61-linux-glibc27-i686/2.61/python
read blend: /opt/morse/share/morse/data/morse_default_autorun.blend
IOError: Python file "/home/mybox/ros_example.py" could not be opened: No such file or directory
Detected GL_ARB_texture_env_combine
Detected GL_ARB_texture_cube_map
Detected GL_ARB_multitexture
Detected GL_ARB_shader_objects
Detected GL_ARB_vertex_shader
Detected GL_ARB_fragment_shader
Detected GL_ARB_vertex_program
Detected GL_ARB_depth_texture
Blender Game Engine Started
Error: Not freed memory blocks: 4
VIEW3D_OT_game_start len: 120 0xad9bcfe0
wmOperatorPtrRNA len: 12 0xb6a74fe0
IDProperty group len: 76 0xadae09a0
wmOperatorReportList len: 28 0xb6ce4c60
Blender quit
X Error of failed request: BadDrawable (invalid Pixmap or Window parameter)
Major opcode of failed request: 14 (X_GetGeometry)
Resource id in failed request: 0x3400002
Serial number of failed request: 5731
Current serial number in output stream: 5731
Originally posted by bossdog22 on ROS Answers with karma: 3 on 2013-04-27
Comment by silgon on 2013-12-23:
I have the same issue, did you find an answer???
Comment by bossdog22 on 2013-12-23:
I believe it was a hardware issue. Blender/MORSE didn't like the AMD cpu & ATI video card combo. I run the VM on another machine that has an Intel cpu & an NVIDIA video card without any problem. You can get away with an AMD cpu & an NVIDIA video combo but I haven't seen a whole lot of success with AMD & ATI combos.
In the end I had the first error of pulseaudio (PulseAudio returned minreq > tlength/2..........) with an update I needed from the sound driver, I downgraded it afterwards. Anyway, I was doing a new installation in my machine, I had the error with the ros sync, because the simulation without ros seemed to be working well, nevertheless, I need further testing but right now I have it working.
Hello!
Running 3D applications from a virtual machine is generally speaking a bad idea. Even if you get a correct display, performances are likely to be poor.
Based on the error message (Major opcode of failed request: 14 (X_GetGeometry)), it looks like the VM 3D driver does not support an OpenGL primitive required by Blender.
Besides, you should update both Ubuntu and MORSE to their latest version (the 3D drivers have improved a lot over the last 2 years).
Last point: we usually recommend MORSE users to use answer.ros.org to ask questions related to MORSE + ROS. For 'MORSE only' questions, it is usually preferable to drop a mail to [email protected] or to fill a bug on MORSE GitHub repository.
Originally posted by severin with karma: 240 on 2013-12-23
