In general, adding 'from [the] internet' to your question doesn't really add much to the already asked question.
If, by 'from [the] internet', you mean 'on a computer connected to the internet', networking is already baked into ROS, so rosbridge is not necessary. You need to learn about the ROS_MASTER_URI and possibly the ROS_IP environment variables.
If, on the other hand, you mean 'from within a web browser', then yes, rosbridge can serve as a tool to help you do that. You can look at the list of experimental ROS client libraries; specifically, you'd likely be interested in rosnodejs. Even more specifically, you should look into robot web tools, and even more specifically than that, at the Widgets section on the Tools page.
Originally posted by kramer with karma: 1470 on 2016-06-25
Comment by swati shirke on 2016-07-17:
Thank you very much!!
