Hi,
When I try to launch the pylon_camera node, I receive the following error:
startGrabbing: Node is not writable.
I traced through the code and found that an exception is thrown when the node is trying to set the PixelFormat to Mono8 using the setValue function in pylon_camera_base.hpp in the startGrabbing function.
I'm using the basler ace acA4600-7gc GigE camera with pylon 5 sdk. I can view the camera images and set camera parameters just fine using the PylonViewerApp.
Any advice?
Thanks, Michael
Originally posted by m.anderson on ROS Answers with karma: 91 on 2016-06-20
Comment by gvdhoorn on 2016-06-21:
You might want to report this on the pylon_camera
package issue tracker. Do please report back if/when you receive a reply.
