Hi, everyone. Im learning ROS tutorials on wiki.When I first use roslaunch according to the beginner level tutorial, there is something wrong. I don't know why it shows that there is a syntax error at line 1,column 3 cause I just copy the code on tutorial. Please tell me why.
input:
roslaunch beginner_tutorials turtlemimic.launch
output:
logging to /home/bit/.ros/log/........long number....../roslaunch-bit-auto-6902.log
checking log directory for disk usage. This may take awhile.
press ctrl-c to interrupt
done checking log file disk usage. usage is <1GB
/the following r red words/
invalid roslaunch xml syntax: syntax error: line 1,column 3
the traceback for the exception was written to the log file
This is the turtlemimic.launch file.
1 <launch>
3 <group ns="turtlesim1">
4 <node pkg="turtlesim" name="sim" type="turtlesim_node"/>
5 </group>
6
7 <group ns="turtlesim2">
8 <node pkg="turtlesim" name="sim" type="turtlesim_node"/>
9 </group>
10
11 <node pkg="turtlesim" name="mimic" type="mimic">
12 <remap from="input" to="turtlesim1/turtle1"/>
13 <remap from="output" to="turtlesim2/turtle1"/>
14 </node>
15
16 </launch>
Originally posted by blairlpp on ROS Answers with karma: 31 on 2016-05-23
Comment by gvdhoorn on 2016-05-24:
Without seeing your launch file this is going to be rather difficult. Please copy/paste the contents of the launch file you created into your original question. Please use the edit button/link for that (and format it using the Preformatted text button - the one with 101010
on it).
Comment by blairlpp on 2016-05-25:
Thanks for ur help. I just used the Preformatted text button to upload my code. Do I use it right? Hope ur reply.
