I have been trying to view my stereo disparity image using image_view stereo_view
but whenever i run it i get two blank left and right windows with the following error in terminal
init done opengl support available
(stereo_view:14758): GLib-GObject-WARNING **: invalid uninstantiatable type '(null)' in cast to 'GtkWidget'
(stereo_view:14758): GLib-GObject-WARNING **: instance of invalid non-instantiatable type '(null)'
(stereo_view:14758): GLib-GObject-CRITICAL **: g_signal_connect_data: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
(stereo_view:14758): GLib-GObject-CRITICAL **: g_signal_connect_data: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed [ INFO] [1453739975.777426383]: Subscribing to:
* /camera/left/image_rect_color
* /camera/right/image_rect_color
* /camera/disparity
I was able to get the images in rviz using
camera
displayI am using ubuntu 14.04 with indigo distro
how can i fix this problem?
anybody please help me
Originally posted by Azharudeen on ROS Answers with karma: 90 on 2016-01-25
Comment by Ariel on 2016-03-17:
Have you solved this?
Comment by sophie.shin on 2017-04-21:
Did you solve this problem? can you please share the solution?
