Hi!
I am reading in point clouds from *.pcd-files and am visualizing them using RViz. Unfortunately, the point cloud is weirdly oriented:
Look here (the "right" side of the point cloud is actually the floor)
I believe that this is because ROS uses a different coordinate system than PCL (or at least than how these pointclouds have been recorded). How do I display my point cloud correctly?
After reading through some tutorials I think I need to implement a tf-broadcaster that transforms between a "world" frame (ROS coordinate system) and a "pcd" frame (coordinate system used in my files). Then I can set the world-frame as fixed frame in Rviz and as a transformation for the PointCloud2 display my broadcasted transformation. Is that correct? Or is there a more elegant way of getting Rviz to display the point cloud "correctly"?
Thanks!
Originally posted by Jay4Ros on ROS Answers with karma: 35 on 2015-12-04
