I'm running roscore on a remote computer.
I created a modified RosRunClass to manually set master URI.
final String master = argv[argv.length - 1]; // http://10.159.1.24:11311
nodeConfiguration.setMasterUri(new URI(master));
I've also overridden Advertise URI as follows:
AdvertiseAddressFactory adress = new AdvertiseAddressFactory() {
String _master = master;
@Override
public AdvertiseAddress newDefault() {
String IPADDRESS_PATTERN = "(?:(?:25[0-5]|2[0-4][0-9]|[01]?[0-9][0-9]?)\\.){3}(?:25[0-5]|2[0-4][0-9]|[01]?[0-9][0-9]?)";
Pattern pattern = Pattern.compile(IPADDRESS_PATTERN);
Matcher matcher = pattern.matcher(_master);
if (matcher.find()) _master = matcher.group();
else _master = "localhost";
return new AdvertiseAddress(_master);
nodeConfiguration.setXmlRpcAdvertiseAddressFactory(adress);
nodeConfiguration.setTcpRosAdvertiseAddressFactory(adress);
However I still get following exception when I try to register a new Publisher.
org.ros.exception.RosRuntimeException: java.net.URISyntaxException: Illegal character in authority at index 7: http://10.159.1.24 192.168.56.1:60076/
I have no idea where "192.168.56.1" comes from as this is NOT my internal (nor external) IP.
I'm using newest rosjava available in Ubuntu repositories (for ros indigo).
Originally posted by smihael on ROS Answers with karma: 45 on 2015-08-17
