I have two computers, both running Ubuntu 12.04 and ROS Hydro. I have a Pioneer3-DX robot which I am running with p2os
on one computer connect to the robot by serial cable. They are connected wirelessly through a dlink router and are able to ping each other by IP address, but not by hostname. I am working through the ROS Multiple Machines Tutorial, and am not able to get the talker/listener working. The error which comes up is:
[ERROR] Unable to immediately register with master node [http://rickoFNP14eedX3:11311]: master may not be running yet. Will keep trying.
Objective: Control the Pioneer3-DX wirelessly from my laptop with teleop_keyboard
I am relatively new at ROS and not great at networking, so thanks for your help on this noob question.
Update:
I used export ROS_MASTER_URI=http://192.168.0.100:11311
on both machines rather than export ROS_MASTER_URI=http://rickoFNP14eedX3:11311
. Starting talker.py
on the onboard machine and listener.py
on the laptop, the error no longer comes up; however, the listener.py
on the laptop does not produce any results.
rostopic list -v
on the laptop shows /chatter
as a published topic with a subscriber. However rostopic echo /chatter
has no results from the laptop.
rostopic list -v
on the onboard machine shows /chatter
as a published topic with a subscriber. rostopic echo /chatter
shows the expected messages.
The results are the same if switch the nodes running on each computer.
Information of laptop:
jslum@rickoFNP14eedX3:~$ hostname
rickoFNP14eedX3
jslum@rickoFNP14eedX3:~$ ifconfig
eth0 Link encap:Ethernet HWaddr 14:da:e9:bf:50:16
inet6 addr: fe80::16da:e9ff:febf:5016/64 Scope:Link
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:220833 errors:0 dropped:0 overruns:0 frame:0
TX packets:15739 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:39199895 (39.1 MB) TX bytes:2154737 (2.1 MB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:157699 errors:0 dropped:0 overruns:0 frame:0
TX packets:157699 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:11060159 (11.0 MB) TX bytes:11060159 (11.0 MB)
wlan0 Link encap:Ethernet HWaddr bc:77:37:e7:db:9b
inet addr:192.168.0.100 Bcast:192.168.0.255 Mask:255.255.255.0
inet6 addr: fe80::be77:37ff:fee7:db9b/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:10496 errors:0 dropped:0 overruns:0 frame:0
TX packets:8736 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:2626670 (2.6 MB) TX bytes:1084552 (1.0 MB)
Information of onboard computer:
ecejames01@ECE521:~$ hostname
ECE521
ecejames01@ECE521:~$ ifconfig
eth0 Link encap:Ethernet HWaddr 00:0a:9d:e0:08:e4
RX packets:304 errors:0 dropped:0 overruns:0 frame:0
TX packets:28624 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:82259 (82.2 KB) TX bytes:5861182 (5.8 MB)
RX packets:7216011 errors:0 dropped:0 overruns:0 frame:0
TX packets:7216011 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:244946501281 (244.9 GB) TX bytes:244946501281 (244.9 MB)
wlan1 Link encap:Ethernet HWaddr c4:d9:87:eb:90:fb
inet addr:192.168.0.101 Bcast:192.168.0.255 Mask:255.255.255.0
inet6 addr: fe80::c6d9::87ff:feb:90fb/64 Scope:Link
RX packets:8273 errors:0 dropped:0 overruns:0 frame:0
TX packets:4890 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:2417399 (2.4 MB) TX bytes:473450 (473.4 KB)
Originally posted by sealguy77 on ROS Answers with karma: 323 on 2015-03-17
