The install and uninstall scripts, although autocompleted when calling rosrun robot_upstart ...
, are NOT present hence the package is completely useless.
rosrun
can only autocomplete things that are actually there. If I look at the CMakeLists.txt for robot_upstart
in its indigo-devel
branch, the install targets seem to be there:
file(GLOB SCRIPTS scripts/*)
install(PROGRAMS ${SCRIPTS} DESTINATION ${CATKIN_PACKAGE_BIN_DESTINATION})
install(DIRECTORY templates DESTINATION ${CATKIN_PACKAGE_SHARE_DESTINATION})
Could you perhaps be looking at the wrong directory? The package manifest and "CMake file, templates and a few other useless files" are installed in /opt/ros/indigo/share/robot_upstart
, while the scripts should be in /opt/ros/indigo/lib/robot_upstart
. The Python package robot_upstart
should be in /opt/ros/indigo/lib/python2.7/dist-packages/robot_upstart
Originally posted by gvdhoorn with karma: 86574 on 2015-07-17
Comment by rbaleksandar on 2015-07-17:
Ah, yes, indeed I was looking in the wrong directory. Those things are in the lib folder of indigo's installation folder and also the Python package is there too. Thanks! PS: This still does not explain why rosrun was telling me that install and respectively uninstall could not be found.
Comment by ahendrix on 2015-07-17:
You did not mention or include any error from rosrun in your original post; please include the exact command you're running and it's exact output and we'll try to help.
Comment by rbaleksandar on 2015-07-18:
I forgot to use source on my .bashrc hence the changes in ROS' installation were not noticed and rosrun reported that "install" is not a known command. It's working now. :)
