Hi,
So I'm trying to transform a PointCloud2 using the method: transformPointCloud (const std::string &target_frame, const sensor_msgs::PointCloud2 &in, sensor_msgs::PointCloud2 &out, const tf::TransformListener &tf_listener)
Here is my code:
class SubscribeAndPublish
public:
  SubscribeAndPublish()
    sub_ = n_.subscribe("/camera/depth/points", 1, &SubscribeAndPublish::callback, this);
    base_link = new std::string("base_link");
  void callback(const sensor_msgs::PointCloud2::ConstPtr& msg)
    tf::Transform transform;
    transform.setOrigin( tf::Vector3(0.0, 0.0, 0.0) );
    tf::Quaternion q;
    q.setRPY(0, 0, 0);
    transform.setRotation(q);
    br.sendTransform(tf::StampedTransform(transform, msg->header.stamp, "base_link", "camera_link"));
    pcl_ros::transformPointCloud(*base_link, transform, *msg, *msgOut);
private:
  ros::NodeHandle n_;
  ros::Subscriber sub_;
  tf::TransformBroadcaster br;
  boost::shared_ptr<sensor_msgs::PointCloud2> msgOut;
  boost::shared_ptr<tf::TransformListener> listener;
  std::string *base_link;
  ros::init(argc, argv, "subscribe_and_publish");
  SubscribeAndPublish SAPObject;
  ros::Rate r(10);
  while(ros::ok()) {
    ros::spinOnce();
    r.sleep();
  return 0;
I have created the transform broadcaster so that I could visualize the transform in rviz and using the same transform to transform the PointCloud since I need to do some calculations on it (find the highest z coordinate when the PointCloud is transformed to be horizontal, but I can't do it on the original cloud since the PointCloud is tilted). I haven't added any numbers to tf::Quaternion q; q.setRPY(0, 0, 0) atm, but I will later.
However when i run the code i get an error: Segmentation fault (core dumped).
Originally posted by RosFan19 on ROS Answers with karma: 107 on 2015-03-12
Your msgOut is probably NULL.
Originally posted by dornhege with karma: 31395 on 2015-03-12
