Hello Folks,
I am in need of a GPS device that currently works with ROS that has a better accuracy than 1 meter.
Does anyone have any suggestions or information that could help.
Originally posted by T00Tall on ROS Answers with karma: 11 on 2014-12-10
Clearpath tends to supply the NovAtel SMART-6 when clients need such accuracy. It'll go down to 2 cm if the right upgrade options are selected, a base station is available, and everything's configured properly (warning: Don't underestimate the configuration time). It works with the standard navsat driver as well.
Originally posted by Ryan with karma: 3248 on 2014-12-10
Comment by T00Tall on 2014-12-10:
Thank you for you're answer. Do you happen to know of any database of nmea compatible devices? To top off my request I forgot to mention we need the device to be relatively small.
Comment by Ryan on 2014-12-11:
I can't think of any database, no. AFAIK, GPS devices which can't be configured for NMEA output are rare.
You can run any device that provides you NMEA ASCII output to the serial port in ROS using the nmea_nav_sat_driver http://wiki.ros.org/nmea_navsat_driver.
E. g. we use a predecessor device of TopCon's GR-5 (http://www.topconpositioning.eu/gnss/integrated-gnss-receivers/gr-5) with UTMS RTK support to reach sub meter accuracy; no additional ROS driver needed!
Originally posted by Wolf with karma: 7555 on 2014-12-10
