As part of my PhD field work it would be useful to have latitude/longitude measurements for the locations of ant nests that I am working on. These ant nests can be as close as 50cm together so the accuracy of the system would (I think) need to be higher than is available from a phone or basic GPS system. Does anyone know what system would be best for getting this sort of accuracy? My budget is probably only around £200. If it isn't possible in that price range it would be good to know what system I would need to use so that I can see if I can just borrow such a system.
Thanks a lot!
  • $\begingroup$ You can try to look for dual GPS recievers. These enhance the precision of GPS, but I doubt that it will be as precise as your spec. Would fit your budget though... $\endgroup$
    – 50k4
    Commented Dec 21, 2016 at 11:48
  • $\begingroup$ OK great, I'll have a look at that then! $\endgroup$
    – unknown
    Commented Dec 21, 2016 at 11:57
  • $\begingroup$ You can get sub-metre precision from an SBAS receiver, but you'll need line-of-sight visibility to the SBAS satellite for your area of the world. $\endgroup$ Commented Feb 8, 2017 at 13:27
  • $\begingroup$ UBlox C94-M8P RTK kit dual-receiver promises 2-cm precision using a fixed and a rover GPS that communicate over UHF. It's 359€. $\endgroup$ Commented Feb 8, 2017 at 13:36
I suggest you are going to look into Chen at al 2015 "Computationally efficient carrier integer ambiguity resolution in multiepoch gps/ins: a common-position-shift approach" This is a very good paper, which allows location down to a centimeter level. Anyway this approach is not plug and play, I fear you have to implement it on your own. I'm not aware of any open source implementation so far. More over if you are trying to locate the ants within a forest, then gps is a not the best approach. Gps uses some wavelengths which are absorbed easily by water and well the trees do contain at lot of water. Long story told short: gps in the forest will never be as accurate as you need.
I know this is not the answer you expected, hope it can help a bit
  • $\begingroup$ OK I guess that won't work very well then. Thanks a lot for your help! $\endgroup$
    – unknown
    Commented Feb 6, 2017 at 10:50
