I've been trying to figure out the same thing. Surprisingly there is no clear cut instruction anywhere. Anyhow, I wanted to convert 2D pixel coordinates (u,v) to X,Y,Z from a point cloud that I got from kinect. I wrote a function to do it, I pass in the point cloud message, u and v coordinates (for a feature in 2D image) and pass a reference to a geometry_msgs point which will get the X,Y,Z values. These X,Y,Z values are in the camera's frame, (X is seen as going from left to right in the image plane, Y is top to bottom and Z pointing into the world).
#include <ros/ros.h>
#include <geometry_msgs/Point.h>
#include <sensor_msgs/PointCloud2.h>
Function to convert 2D pixel point to 3D point by extracting point
from PointCloud2 corresponding to input pixel coordinate. This function
can be used to get the X,Y,Z coordinates of a feature using an
RGBD camera, e.g., Kinect.
void pixelTo3DPoint(const sensor_msgs::PointCloud2 pCloud, const int u, const int v, geometry_msgs::Point &p)
// get width and height of 2D point cloud data
int width = pCloud.width;
int height = pCloud.height;
// Convert from u (column / width), v (row/height) to position in array
// where X,Y,Z data starts
int arrayPosition = v*pCloud.row_step + u*pCloud.point_step;
// compute position in array where x,y,z data start
int arrayPosX = arrayPosition + pCloud.fields[0].offset; // X has an offset of 0
int arrayPosY = arrayPosition + pCloud.fields[1].offset; // Y has an offset of 4
int arrayPosZ = arrayPosition + pCloud.fields[2].offset; // Z has an offset of 8
float X = 0.0;
float Y = 0.0;
float Z = 0.0;
memcpy(&X, &pCloud.data[arrayPosX], sizeof(float));
memcpy(&Y, &pCloud.data[arrayPosY], sizeof(float));
memcpy(&Z, &pCloud.data[arrayPosZ], sizeof(float));
// put data into the point p
p.x = X;
p.y = Y;
p.z = Z;
Originally posted by Saurav Agarwal with karma: 246 on 2016-11-03
Post score: 7
Comment by zubair on 2017-04-20:
https://pastebin.com/i71RQcU2 this is my code,, whose part i took from above code,, please have a look , i am not getting x y z values
Comment by Teddy_NTU on 2019-03-07:
Thanks a lot, your code really helps me out.
Comment by Chao Chen on 2020-06-19:
How do we obtain u and v value from unordered pointcloud2 message genereated by the camera?
Why Z value generated stays at 0 all the time?
[ INFO] [1592594247.545080677]: X:0.001937
[ INFO] [1592594247.545595176]: Y:4.224004
[ INFO] [1592594247.546480684]: Z:0.000000
[ INFO] [1592594247.609789284]: X:0.002125
[ INFO] [1592594247.610029254]: Y:4.496003
[ INFO] [1592594247.610784074]: Z:0.000000
[ INFO] [1592594247.695069364]: X:0.002029
[ INFO] [1592594247.696253339]: Y:4.368001
[ INFO] [1592594247.696658301]: Z:0.000000
[ INFO] [1592594247.746237034]: X:0.002519
[ INFO] [1592594247.747699666]: Y:4.768003
[ INFO] [1592594247.748495863]: Z:0.000000
[ INFO] [1592594247.823073068]: X:0.000709
[ INFO] [1592594247.823236717]: Y:2.464001
[ INFO] [1592594247.824035601]: Z:0.000000
Comment by flynneva on 2021-04-22:
you should check out the depth image processing package. I think it has what you need!
