Hello,
I'm working with velodyne 32E and I was subscribing a node from "velodyne_driver" to read data from the topic "velodyne_packets" but the code in the callback wasn't executed everytime the topic was published by the LIDAR. (In callback it just had a counter incrementing, only printing the counter out of callback when the bag file ends or if press Ctrl+C)
I thought if I could change my code to use a nodelet instead of a node to direct access to data but i didn't find how to make it.
To subscribe a node it very easy because then is "sends me" to a callback just like an interruption (I think) and I could do whatever I wanted with the data. But with nodelets it is different and I didn't realized yet how could I get the data in real time.
I want to read directly from nodelet, not to transform a node into a nodelet!
Could you help me?
Thank you, Oportoz
CODE:
#includes.........
int i;
void callback(const velodyne_msgs::VelodyneScan::ConstPtr& msg)
 i++;
int main(int argc, char** argv)
    ros::init(argc, argv, "subscribe_pack");
    ros::NodeHandle nh;
    ros::Subscriber sub = nh.subscribe<velodyne_msgs::VelodyneScan>("/velodyne_packets", 1, callback);
  while(ros::ok())
        ros::spin(); //
  std::cout << i << std::endl;
return 0;
Originally posted by Oportoz on ROS Answers with karma: 1 on 2014-06-26
Untested approximation to your node:
#include <ros/ros.h>
#include <pluginlib/class_list_macros.h>
#include <nodelet/nodelet.h>
namespace your_package
  class YourNodelet: public nodelet::Nodelet
  public:
    YourNodelet() {}
    ~YourNodelet()
      std::cout << i_ << std::endl;
  private:
    virtual void onInit();
    int i_;
    ros::Subscriber sub_;
  /** @brief Nodelet initialization. */
  void YourNodelet::onInit()
    i_ = 0;
    nh = getNodeHandle()
    sub_ =  nh.subscribe("velodyne_packets", 10, &YourNodelet::callback,
                         (YourNodelet *) this, ros::TransportHints().tcpNoDelay(true));
  void YourNodelet::callback(const velodyne_msgs::VelodyneScan::ConstPtr &scanMsg)
    ++i_;
} // namespace your_package
// Register this plugin with pluginlib.  Names must match nodelet_velodyne.xml.
// parameters: package, class name, class type, base class type
PLUGINLIB_DECLARE_CLASS(your_package, YourNodelet,
                        your_package::YourNodelet, nodelet::Nodelet);
Originally posted by joq with karma: 25443 on 2014-06-26
Comment by Oportoz on 2014-06-26:
Thank you joq. I will try this way and then I post here the news.
Regards
