Hi everyone,
I want to turn my robot x degrees to face a desired coordinate(goal). The robot must turn about 100 degrees (1.745 radians), but when I set the angular velocity to 1.745 since the program is running in a loop it doesn't execute the command completely and I don't know how to stop the program at that time to let the turn complete. I thought maybe the robot is not capable of turning at 1.745 radians when received the command, so I thought maybe I should divide 1.745 by, say, 5 and turn the robot 5 times. But I don't know how I can MAKE SURE that the robot has executed the 5 commands I publish.
Thank you
Originally posted by Warrior on ROS Answers with karma: 61 on 2014-04-18
