Hello,
I have some ROS C++ packages that share many common functions.
They are identical functions so I was thinking to put them all in another file.hpp and include this file in each package is needing them.
I'm using catkin to create my workspace and all the packages I develop. They are all in src directory starting from the main one, as the tutorials said.
But where do I must save this file.hpp in the workspace and which path I have to #include in each file that is using it? Do I have to modify the CMakeLists.txt?
This is a scheme of my workspace:
  • build
  • devel
  • src
    package 1
    CMakeLists.txt
    src (file.cpp are here)
    include
    package1.xml
    package 2
Thanks in advance.
Originally posted by eds on ROS Answers with karma: 101 on 2013-12-11
The library package @dornhege recommends should be built like this:
If you only provide headers and no libraries, skip the library build and installation instructions. But, you should install the headers.
You other packages will reference it like this:
Originally posted by joq with karma: 25443 on 2013-12-12
The ROS way would be to create a package for these common functions. The common code goes in there either as a header or built as a library.
All other packages that need this would then just depend on this package.
Originally posted by dornhege with karma: 31395 on 2013-12-11
Comment by eds on 2013-12-12:
Thank you, can you make an example? I can create a package but how do I must make the others dependable by this one? Do I have to put some extra #include, CMakeLists or package.xml statement?
