Hello community!
I have a question concerning the clearpath husky A200 gazebo model. I set up a simulation for our husky in gazebo. After I got it running, I was able to control the husky model the same way as our "real" husky, running the same nodes in the simulation as on the real husky.
But there is a strange behaviour in gazebo during steering the model. It seems as if the steering/turning speed in gazebo is very slow compared to the "real" husky.
To get some numbers, I ran the "robot_pose_ekf" package to see some odometry data in rviz. When moving forward and backward on a strait line the data seems to be OK, but the turning speed is very different. For example, a 360° spot turn in gazebo are nearly 1080° in RVIZ regarding the odometry data.
Does anyone have some experience with this issue?
Regards psei
Originally posted by psei on ROS Answers with karma: 318 on 2013-08-18
Comment by pmukherj on 2013-08-21:
Hello!
This maybe because the "real" husky is running in open loop mode while the simulated one is not. I can verify this but just so I understand the problem well. I am assuming the "real" husky has an IMU? So the 1080 degree you turn you saw in rviz is something you observed physically as well?
