Gazebo Answers logo
My situation is the following: I have a working robot model with a head_hokuyo_sensor as laser range finder. When using this model on my default setup, everything works fine. When using the model on a virtual machine, Gazebo crashes when the range readings are requested.
At first I thought Gazebo crashed any time when launched in the virtual machine. This is not true. It only crashes when the range readings are requested, either by visualization (as was default in my first try), or by ROS rviz. This is the output when the model is launched and the data is requested by rviz:
$ roslaunch p3dx_gazebo gazebo.launch
... logging to /home/gazebo/.ros/log/0c658438-357b-11e3-952c-080027a2ea94/roslaunch-gazebo-VirtualBox-10513.log
Press Ctrl-C to interrupt
started roslaunch server http://gazebo-VirtualBox:44541/
SUMMARY
PARAMETERS
 * /robot_description
 * /rosdistro
 * /rosversion
 * /use_sim_time
NODES
    gazebo (gazebo_ros/gzserver)
    gazebo_gui (gazebo_ros/gzclient)
    urdf_spawner (gazebo_ros/spawn_model)
core service [/rosout] found
process[gazebo-1]: started with pid [10534]
process[gazebo_gui-2]: started with pid [10539]
process[urdf_spawner-3]: started with pid [10546]
Gazebo multi-robot simulator, version 1.9.1
Copyright (C) 2013 Open Source Robotics Foundation.
Released under the Apache 2 License.
http://gazebosim.org
Msg Waiting for master.spawn_model script started
[ INFO] [1381829287.748584629]: Finished loading Gazebo ROS API Plugin.
[1;[ INFO] [1381829287.754626059]: waitForService: Service [/gazebo/set_physics_properties] has not been advertised, waiting...
32mMsg Waiting for master
Msg Connected to gazebo master @ http://127.0.0.1:11345
Msg Publicized address: 10.0.2.15
OpenGL Warning: Failed to connect to host. Make sure 3D acceleration is enabled for this VM.
libGL error: failed to load driver: vboxvideo
libGL error: Try again with LIBGL_DEBUG=verbose for more details.
[INFO] [WallTime: 1381829287.963248] [0.000000] Loading model xml from ros parameter
[INFO] [WallTime: 1381829287.969376] [0.000000] Waiting for service /gazebo/spawn_urdf_model
[INFO] [WallTime: 1381829288.279075] [0.000000] Calling service /gazebo/spawn_urdf_model
Error [Param.cc:181] Unable to set value [1,0471975511965976] for key[horizontal_fov]
Error [Param.cc:181] Unable to set value [0,100000001] for key[near]
Warning [parser.cc:356] No <sdf> element in file[data-string]
[INFO] [WallTime: 1381829294.465796] [0.001000] Spawn status: SpawnModel: Successfully spawned model
[ INFO] [1381829294.500488438, 0.001000000]: LoadThread function completed
[ INFO] [1381829294.578569308, 0.001000000]: Loading gazebo_ros_control plugin
[ INFO] [1381829294.583119526, 0.001000000]: Starting gazebo_ros_control plugin in namespace: /p3dx
[ INFO] [1381829294.587561148, 0.001000000]: gazebo_ros_control plugin is waiting for model URDF in parameter [/robot_description] on the ROS param server.
[urdf_spawner-3] process has finished cleanly
log file: /home/gazebo/.ros/log/0c658438-357b-11e3-952c-080027a2ea94/urdf_spawner-3*.log
[ INFO] [1381829295.363769657, 0.001000000]: Loaded gazebo_ros_control.
[ INFO] [1381829295.372589215, 0.001000000]: Starting GazeboRosDiffDrive Plugin (ns = //)!
[ INFO] [1381829295.437790648, 0.021000000]: waitForService: Service [/gazebo/set_physics_properties] is now available.
[ INFO] [1381829295.612645974, 0.081000000]: Physics dynamic reconfigure ready.
Segmentation fault (core dumped)
[gazebo-1] process has died [pid 10534, exit code 139, cmd /opt/ros/hydro/lib/gazebo_ros/gzserver /home/gazebo/catkin/src/ua_ros_p3dx/p3dx_gazebo/worlds/p3dx.world __name:=gazebo __log:=/home/gazebo/.ros/log/0c658438-357b-11e3-952c-080027a2ea94/gazebo-1.log].
log file: /home/gazebo/.ros/log/0c658438-357b-11e3-952c-080027a2ea94/gazebo-1*.log
The model can be found here: https://github.com/RafBerkvens/ua_ros_p3dx/blob/master/p3dx_description/urdf/pioneer3dx.xml
Some OpenGL and LibGL errors can be seen during start-up, caused by the virtual machine to have disable 3D acceleration. Turning this on does not resolve the issue, but causes many errors. These errors are in turn resolved by using export LIBGL_ALWAYS_SOFTWARE=1, which can be found in this ROS answer. Of course, this is the same as not using 3D acceleration, resulting in the mentioned error, again.
I can not reproduce this error on my host machine (Ubuntu 13.04 64-bit; guest is Ubuntu 13.04 32-bit). At the host, everything works like it should.
I have been able to collect this backtrace:
Program received signal SIGSEGV, Segmentation fault.
0xb62ae708 in Ogre::Technique::getPass(unsigned short) ()
   from /usr/lib/i386-linux-gnu/libOgreMain.so.1.7.4
(gdb) backtrace
#0  0xb62ae708 in Ogre::Technique::getPass(unsigned short) ()
#1  0xb70090f1 in gazebo::rendering::GpuLaser::UpdateRenderTarget(Ogre::RenderTarget*, Ogre::Material*, Ogre::Camera*, bool) ()
   from /usr/lib/libgazebo_rendering.so.1
#2  0xb7009813 in gazebo::rendering::GpuLaser::RenderImpl() ()
#3  0xb6fdbc1f in gazebo::rendering::Camera::Render() ()
#4  0xb7bd97e2 in gazebo::sensors::GpuRaySensor::UpdateImpl(bool) ()
   from /usr/lib/libgazebo_sensors.so.1
#5  0xb7bf0c40 in gazebo::sensors::Sensor::Update(bool) ()
#6  0xb7bf6bd4 in gazebo::sensors::SensorManager::SensorContainer::Update(bool)
    () from /usr/lib/libgazebo_sensors.so.1
#7  0xb7bf723c in gazebo::sensors::SensorManager::ImageSensorContainer::Update(bool) () from /usr/lib/libgazebo_sensors.so.1
#8  0xb7bf7dec in gazebo::sensors::SensorManager::Update(bool) ()
#9  0xb7bef390 in gazebo::sensors::run_once(bool) ()
#10 0x0806f651 in gazebo::Server::Run() ()
#11 0x0806ada0 in main ()
Originally posted by RafBerkvens on Gazebo Answers with karma: 33 on 2013-10-15
Comment by RafBerkvens on 2013-10-15:
I thought to have solved it by installing ros-hydro-hokuyo-node, but it results in the same error. The libGL errors can be resolved by turning on 3D acceleration and using export LIBGL_ALWAYS_SOFTWARE=1, but this does also not resolve the segmentation fault when the range readings are requested.
Comment by nkoenig on 2013-10-15:
Can you post a backtrace? It would be most useful if you try running gazebo with any ROS infrastructure.
Comment by RafBerkvens on 2013-10-16:
I have tested the setup with the new Gazebo 2.0. The backtrace is the same.
Gazebo Answers logo
The solution was, of course, simple.
The model used the libgazebo_ros_gpu_laser.so. Since Gazebo proved to be unable to run on virtual GPU ussage (export LIBGL_ALWAYS_SOFTWARE=1 was necessary to run Gazebo using hardware acceleration), it could not access the GPU. Changing the plugin to libgazebo_ros_laser.so and sensor type to ray solved the issue.
The hint was found in this discussion: https://bitbucket.org/osrf/gazebo/issue/760/uneven-sdf-model-updates-cuase, which was found thanks to the backtrace suggested by @nkoening.
Originally posted by RafBerkvens with karma: 33 on 2013-10-16
Comment by Raul Gui on 2015-05-21:
Solve my problem :)
