Hello there, i'm trying to launch the procrob_funtional face recognition tool via launchfile. By starting the Fserver via rosrun you have to go to the directory in which the "facedata.xml" etc. are stored. How can I realize that in a launchfile? I'm using ros groovy and the following code:
<launch>
<node name="usb_cam" pkg="usb_cam" type="usb_cam_node" output="screen" >
<param name="video_device" value="/dev/video0" />
<param name="image_width" value="640" />
<param name="image_height" value="480" />
<param name="pixel_format" value="mjpeg" />
<param name="camera_frame_id" value="usb_cam" />
<param name="io_method" value="mmap"/>
</node>
<node name="Fserver" pkg="face_recognition" type="Fserver" output="screen">
<param name="haarcascade_frontalface_alt" value="$(find face_recognition)/haarcascade_frontalface_alt.xml"/>
<param name="facedata" value="$(find face_recognition)/facedata.xml"/>
<param name="train" value="$(find face_recognition)/train.txt"/>
</node>
<node name="Fclient" pkg="face_recognition" type="Fclient" output="screen">
</node>
</launch>
Thanks for your help!
Originally posted by Bison on ROS Answers with karma: 52 on 2013-02-20
