Hi all,
Information has been updated, but this documentation doesn't mention Gazebo:
http://ros.org/wiki/openni_camera
http://ros.org/wiki/openni_launch
To test a real OpenNI device, I can run:
$ roslaunch openni_launch openni.launch
which will produce all the topics listed below.
If you launch a PR2 or Turtlebot in Gazebo simulation, it only outputs the raw data. So there are no topics like:
/camera/rgb/image_color
What's the best way to launch image_proc & depth_image_proc nodelets?
Will this work?
$ roslaunch openni_launch openni.launch load_driver:=false depth_registration:=true
(I can't test anything at the moment)
Are there any plans to include this with the PR2 or Turtlebot simulators?
(turtlebot_bringup/launch/3dsensor.launch gave me some ideas, but I guess it's only for the real robot)
Thanks,
David.
Topics published from real OpenNI device:
/camera/depth/camera_info
/camera/depth/disparity
/camera/depth/image
/camera/depth/image/compressed
/camera/depth/image/compressed/parameter_descriptions
/camera/depth/image/compressed/parameter_updates
/camera/depth/image/compressedDepth
/camera/depth/image/compressedDepth/parameter_descriptions
/camera/depth/image/compressedDepth/parameter_updates
/camera/depth/image/theora
/camera/depth/image/theora/parameter_descriptions
/camera/depth/image/theora/parameter_updates
/camera/depth/image_raw
/camera/depth/image_raw/compressed
/camera/depth/image_raw/compressed/parameter_descriptions
/camera/depth/image_raw/compressed/parameter_updates
/camera/depth/image_raw/compressedDepth
/camera/depth/image_raw/compressedDepth/parameter_descriptions
/camera/depth/image_raw/compressedDepth/parameter_updates
/camera/depth/image_raw/theora
/camera/depth/image_raw/theora/parameter_descriptions
/camera/depth/image_raw/theora/parameter_updates
/camera/depth/image_rect
/camera/depth/image_rect/compressed
/camera/depth/image_rect/compressed/parameter_descriptions
/camera/depth/image_rect/compressed/parameter_updates
/camera/depth/image_rect/compressedDepth
/camera/depth/image_rect/compressedDepth/parameter_descriptions
/camera/depth/image_rect/compressedDepth/parameter_updates
/camera/depth/image_rect/theora
/camera/depth/image_rect/theora/parameter_descriptions
/camera/depth/image_rect/theora/parameter_updates
/camera/depth/image_rect_raw
/camera/depth/image_rect_raw/compressed
/camera/depth/image_rect_raw/compressed/parameter_descriptions
/camera/depth/image_rect_raw/compressed/parameter_updates
/camera/depth/image_rect_raw/compressedDepth
/camera/depth/image_rect_raw/compressedDepth/parameter_descriptions
/camera/depth/image_rect_raw/compressedDepth/parameter_updates
/camera/depth/image_rect_raw/theora
/camera/depth/image_rect_raw/theora/parameter_descriptions
/camera/depth/image_rect_raw/theora/parameter_updates
/camera/depth/points
/camera/depth/rectify_depth/parameter_descriptions
/camera/depth/rectify_depth/parameter_updates
/camera/depth_registered/camera_info
/camera/depth_registered/disparity
/camera/depth_registered/image
/camera/depth_registered/image/compressed
/camera/depth_registered/image/compressed/parameter_descriptions
/camera/depth_registered/image/compressed/parameter_updates
/camera/depth_registered/image/compressedDepth
/camera/depth_registered/image/compressedDepth/parameter_descriptions
/camera/depth_registered/image/compressedDepth/parameter_updates
/camera/depth_registered/image/theora
/camera/depth_registered/image/theora/parameter_descriptions
/camera/depth_registered/image/theora/parameter_updates
/camera/depth_registered/image_raw
/camera/depth_registered/image_raw/compressed
/camera/depth_registered/image_raw/compressed/parameter_descriptions
/camera/depth_registered/image_raw/compressed/parameter_updates
/camera/depth_registered/image_raw/compressedDepth
/camera/depth_registered/image_raw/compressedDepth/parameter_descriptions
/camera/depth_registered/image_raw/compressedDepth/parameter_updates
/camera/depth_registered/image_raw/theora
/camera/depth_registered/image_raw/theora/parameter_descriptions
/camera/depth_registered/image_raw/theora/parameter_updates
/camera/depth_registered/image_rect
/camera/depth_registered/image_rect/compressed
/camera/depth_registered/image_rect/compressed/parameter_descriptions
/camera/depth_registered/image_rect/compressed/parameter_updates
/camera/depth_registered/image_rect/compressedDepth
/camera/depth_registered/image_rect/compressedDepth/parameter_descriptions
/camera/depth_registered/image_rect/compressedDepth/parameter_updates
/camera/depth_registered/image_rect/theora
/camera/depth_registered/image_rect/theora/parameter_descriptions
/camera/depth_registered/image_rect/theora/parameter_updates
/camera/depth_registered/image_rect_raw
/camera/depth_registered/image_rect_raw/compressed
/camera/depth_registered/image_rect_raw/compressed/parameter_descriptions
/camera/depth_registered/image_rect_raw/compressed/parameter_updates
/camera/depth_registered/image_rect_raw/compressedDepth
/camera/depth_registered/image_rect_raw/compressedDepth/parameter_descriptions
/camera/depth_registered/image_rect_raw/compressedDepth/parameter_updates
/camera/depth_registered/image_rect_raw/theora
/camera/depth_registered/image_rect_raw/theora/parameter_descriptions
/camera/depth_registered/image_rect_raw/theora/parameter_updates
/camera/depth_registered/points
/camera/depth_registered/rectify_depth/parameter_descriptions
/camera/depth_registered/rectify_depth/parameter_updates
/camera/driver/parameter_descriptions
/camera/driver/parameter_updates
/camera/ir/camera_info
/camera/ir/image_raw
/camera/ir/image_raw/compressed
/camera/ir/image_raw/compressed/parameter_descriptions
/camera/ir/image_raw/compressed/parameter_updates
/camera/ir/image_raw/compressedDepth
/camera/ir/image_raw/compressedDepth/parameter_descriptions
/camera/ir/image_raw/compressedDepth/parameter_updates
/camera/ir/image_raw/theora
/camera/ir/image_raw/theora/parameter_descriptions
/camera/ir/image_raw/theora/parameter_updates
/camera/ir/image_rect
/camera/ir/image_rect/compressed
/camera/ir/image_rect/compressed/parameter_descriptions
/camera/ir/image_rect/compressed/parameter_updates
/camera/ir/image_rect/compressedDepth
/camera/ir/image_rect/compressedDepth/parameter_descriptions
/camera/ir/image_rect/compressedDepth/parameter_updates
/camera/ir/image_rect/theora
/camera/ir/image_rect/theora/parameter_descriptions
/camera/ir/image_rect/theora/parameter_updates
/camera/ir/rectify_ir/parameter_descriptions
/camera/ir/rectify_ir/parameter_updates
/camera/projector/camera_info
/camera/rgb/camera_info
/camera/rgb/debayer/parameter_descriptions
/camera/rgb/debayer/parameter_updates
/camera/rgb/image_color/compressed
/camera/rgb/image_color/compressed/parameter_descriptions
/camera/rgb/image_color/compressed/parameter_updates
/camera/rgb/image_color/compressedDepth
/camera/rgb/image_color/compressedDepth/parameter_descriptions
/camera/rgb/image_color/compressedDepth/parameter_updates
/camera/rgb/image_color/theora
/camera/rgb/image_color/theora/parameter_descriptions
/camera/rgb/image_color/theora/parameter_updates
/camera/rgb/image_mono
/camera/rgb/image_mono/compressed
/camera/rgb/image_mono/compressed/parameter_descriptions
/camera/rgb/image_mono/compressed/parameter_updates
/camera/rgb/image_mono/compressedDepth
/camera/rgb/image_mono/compressedDepth/parameter_descriptions
/camera/rgb/image_mono/compressedDepth/parameter_updates
/camera/rgb/image_mono/theora
/camera/rgb/image_mono/theora/parameter_descriptions
/camera/rgb/image_mono/theora/parameter_updates
/camera/rgb/image_raw
/camera/rgb/image_raw/compressed
/camera/rgb/image_raw/compressed/parameter_descriptions
/camera/rgb/image_raw/compressed/parameter_updates
/camera/rgb/image_raw/compressedDepth
/camera/rgb/image_raw/compressedDepth/parameter_descriptions
/camera/rgb/image_raw/compressedDepth/parameter_updates
/camera/rgb/image_raw/theora
/camera/rgb/image_raw/theora/parameter_descriptions
/camera/rgb/image_raw/theora/parameter_updates
/camera/rgb/image_rect
/camera/rgb/image_rect/compressed
/camera/rgb/image_rect/compressed/parameter_descriptions
/camera/rgb/image_rect/compressed/parameter_updates
/camera/rgb/image_rect/compressedDepth
/camera/rgb/image_rect/compressedDepth/parameter_descriptions
/camera/rgb/image_rect/compressedDepth/parameter_updates
/camera/rgb/image_rect/theora
/camera/rgb/image_rect/theora/parameter_descriptions
/camera/rgb/image_rect/theora/parameter_updates
/camera/rgb/image_rect_color
/camera/rgb/image_rect_color/compressed
/camera/rgb/image_rect_color/compressed/parameter_descriptions
/camera/rgb/image_rect_color/compressed/parameter_updates
/camera/rgb/image_rect_color/compressedDepth
/camera/rgb/image_rect_color/compressedDepth/parameter_descriptions
/camera/rgb/image_rect_color/compressedDepth/parameter_updates
/camera/rgb/image_rect_color/theora
/camera/rgb/image_rect_color/theora/parameter_descriptions
/camera/rgb/image_rect_color/theora/parameter_updates
/camera/rgb/rectify_color/parameter_descriptions
/camera/rgb/rectify_color/parameter_updates
/camera/rgb/rectify_mono/parameter_descriptions
/camera/rgb/rectify_mono/parameter_updates
/rosout
/rosout_agg
/tf
Originally posted by dbworth on ROS Answers with karma: 1103 on 2013-01-11
