Following the ROS tutorial, when I'm trying to plot the position of the turtle, I get the following error:
$ rosrun rqt_plot rqt_plot --args /turtle1/pose/x:y
[rosrun] Couldn't find executable named rqt_plot below /opt/ros/fuerte/stacks/rqt/rqt_plot
[rosrun] Found the following, but they're either not files,
[rosrun] or not executable:
[rosrun]   /opt/ros/fuerte/stacks/rqt/rqt_plot
[rosrun]   /opt/ros/fuerte/stacks/rqt/rqt_plot/src/rqt_plot
Any ideas why this might be happening? By the way, rqt_gui works fine.
Originally posted by 3lectrologos on ROS Answers with karma: 3 on 2012-12-12
rqt_plot is a plugin for the gui. If you run rqt_gui, there should be a 'Plugins' menu item in the main window that lets you select a plugin to display. You can then specify the topic in the text box in the panel that comes up.
EDIT: To get more plugins for rqt, just apt-get them, as in the guide here.
Originally posted by thebyohazard with karma: 3562 on 2012-12-12
Post score: 4
Comment by sven_007 on 2013-05-18:
In the 'Plugins' menu item in the main window,there is only one plugin:ROS GRAPH.How can I add other plugins?
