I would like to change the ROS folder location. The current directory is: root/opt/ros but if I just move it (cut, paste), ROS it doesn't work How can I move it to my desktop?
Originally posted by andreapatri on ROS Answers with karma: 26 on 2012-11-13
Comment by SL Remy on 2012-11-14:
Why would you like it to be placed on your desktop?
Usually you would keep the system folder for ROS there and add another folder to your $ROS_PACKAGE_PATH environment variable. I usually like to use ~/ros for my packages or packages I downloaded from other people's repositories.
Originally posted by georgebrindeiro with karma: 1264 on 2012-11-13
Generally, I think it's a pretty bad idea to move ros packages that were installed by debian packages (everything in /opt/ros/). Setting ROS_PACKAGE_PATH will not be enough because the binaries and libraries in ros packages contain RPATH information to not require LD_LIRBARY_PATH set. When you move the packages, the rpaths will become incorrect and you won't be able to run any nodes anymore. A second problem is that every update will re-install ros packages at the old location.
The only thing you can do is creating a symbolic link. You can move /opt/ros and then create the link with:
ln -s /opt/ros <new location of ros>
Originally posted by Lorenz with karma: 22731 on 2012-11-13
Comment by dornhege on 2012-11-14:
You'd want: ln -s /opt/ros
Comment by Lorenz on 2012-11-14:
Damn. Right. Edited my post. Thanks!
