Hello,
I am new to ROS, Ubuntu, and PCL. I have Ubuntu 11.10. I am attempting to complete the ROS PCL Tutorials at http://www.ros.org/wiki/pcl/Tutorials. I got stuck at step 4.1.
I was unable to get the ./voxel_grid command to work in the linked part of the tutorial at the PCL website at http://www.pointclouds.org/documentation/tutorials/voxel_grid.php. I receive the following errors:
albertchi@albertchi-e6510:~/my_pcl_tutorial$ ./voxel_grid
bash: ./voxel_grid: No such file or directory
albertchi@albertchi-e6510:~/my_pcl_tutorial$ ./voxel_grid.cpp
bash: ./voxel_grid.cpp: Permission denied
I tried: albertchi@albertchi-e6510:~$ chmod 777 my_pcl_tutorial, but this did not change the output.
I moved on to the next step in the tutorial (the second part of step 4.1), and tried:
albertchi@albertchi-e6510:~$ rosmake my_pcl_tutorial
[ rosmake ] rosmake starting...
[ rosmake ] Packages requested are: ['my_pcl_tutorial']
[ rosmake ] Logging to directory /home/albertchi/.ros/rosmake/rosmake_output-20121022-112526
[ rosmake ] Expanded args ['my_pcl_tutorial'] to:
[ rosmake ] WARNING: The following args could not be parsed as stacks or packages: ['my_pcl_tutorial']
[ rosmake ] ERROR: No arguments could be parsed into valid package or stack names.
Obviously, this was unsuccessful as well. Suggestions would be appreciated. I am hoping it is something simple because I am new.
Amanda
Originally posted by Amanda on ROS Answers with karma: 11 on 2012-10-22
Comment by jbohren on 2012-10-22:
What does executing ls -la ~/my_pcl_tutorial give?
Comment by Amanda on 2012-10-22:
total 5568
drwxrwxrwx 4 albertchi albertchi 4096 2012-10-22 10:56 .
drwxr-xr-x 36 albertchi albertchi 4096 2012-10-22 09:39 ..
-rw-rw-r-- 1 albertchi albertchi 1569 2012-10-19 16:33 CMakeLists.txt
-rw-rw-r-- 1 albertchi albertchi 1254 2012-10-08 15:06 CMakeLists.txt~
-rw-rw-r-- 1 albertchi albertchi 761 2012-10-08 15:06 example.cpp
drwxrwxr-x 3 albertchi albertchi 4096 2012-10-08 15:01 include
-rw-rw-r-- 1 albertchi albertchi 120 2012-10-08 15:01 mainpage.dox
-rw-rw-r-- 1 albertchi albertchi 41 2012-10-08 15:01 Makefile
-rw-rw-r-- 1 albertchi albertchi 367 2012-10-08 15:01 manifest.xml
drwxrwxr-x 2 albertchi albertchi 4096 2012-10-08 15:01 src
-rw-rw-r-- 1 albertchi albertchi 5649007 2012-10-19 16:51 table_scene_lms400.pcd
-rw-rw-r-- 1 albertchi albertchi 1559 2012-10-22 10:56 voxel_grid.cpp
-rw-rw-r-- 1 albertchi albertchi 1591 2012-10-22 10:56 voxel_grid.cpp~
Sorry this is so long and broken up. Is there a better way for me to post a response in the future?
Comment by Lorenz on 2012-10-22:
Instead of creating a lot of comments, it's better to edit the question.
You need to set up a ROS workspace before you can compile your own packages. Have a look at this page and this tutorial.
Originally posted by Lorenz with karma: 22731 on 2012-10-22
Thank you for the guidance. I attempted to do this using two methods:
I tried to add the my_pcl_tutorial file to the ROS_PACKAGE_PATH using:
albertchi@albertchi-e6510:~$ rosws set ~/my_pcl_tutorial
albertchi@albertchi-e6510:~$ source /home/albertchi/setup.sh
but it returned the same error.
Second Method: I copied the entire my_pcl_tutorial folder into the fuerte_workspace folder and did:
albertchi@albertchi-e6510:~$ rosws set ~/fuerte_workspace/my_pcl_tutorial
You must source ~/fuerte_workspace/setup.bash, not /home/albertchi/setup.sh. The latter file should even not exist at all.
I originally ran source /home/albertchi/setup.sh because the output of rosws set ~/fuerte_workspace/my_pcl_tutorial told me to run that command specifically. Idk why. I ran
albertchi@albertchi-e6510:~$ source ~/fuerte_workspace/setup.bash
and I received the same error as before.
Comment by baogege on 2015-08-08:
do you solve it?I have the same problem.I am using ubuntu12.04+groovy,and I also source ~/my_ws/devel/setup.bash can you help me?
