Hi All,
As a beginner, followed the instructions on http://www.ros.org/wiki/xv_11_laser_driver/Tutorials/Running%20the%20XV-11%20Node to install xv_11 drivers for Neato laser (for beginners, as is marked). When arriving at step 4, getting into trouble :
~/cwru-ros-pkg$ rosmake --rosdep-install xv_11_laser_driver [ rosmake ] Packages requested are: ['xv_11_laser_driver']
[ rosmake ] Logging to directory/home/user/.ros/rosmake/rosmake_output-20111208-221941
[ rosmake ] Expanded args ['xv_11_laser_driver'] to: []
[ rosmake ] WARNING: The following args could not be parsed as stacks or packages: ['xv_11_laser_driver']
[ rosmake ] ERROR: No arguments could be parsed into valid package or stack names.
is this cwru-ros-pkg broken? Or am I doing something else wrong ? (note using cturtle : echo $ROS_ROOT gives /opt/ros/cturtle/ros $ROS_PACKAGE_PATH gives /home/user/cwru-ros-pkg/cwru-ros-pkg:/opt/ros/cturtle/stacks:/opt/ros/diamondback/stacks
Thx for any help !
Grtz, Mvp,
Originally posted by mvp on ROS Answers with karma: 11 on 2011-12-08
The xv_11_laser_driver was accidentally removed from the cwru-ros-pkg repository. It has since been restored, so the directions should work again.
Originally posted by Eric Perko with karma: 8406 on 2012-01-15
