In tutorial http://www.ros.org/wiki/fuerte/Installation/Overlays, I get the result and I did this command In workspace that have .rosinstall:
rosws merge https://kforge.ros.org/turtlebot/turtlebot -t .
But I receive a error:
ERROR: Invalid multiproject yaml format in [https://kforge.ros.org/turtlebot/turtlebot]: mapping values are not allowed here in "", line 8, column 27
Originally posted by leo_eng on ROS Answers with karma: 3 on 2012-08-20
Comment by leo_eng on 2012-08-20:
Ok...but I you can see that I try to do this : http://answers.ros.org/question/41785/roslocate-info-turtlebot-rosws-merge-/
Comment by Lorenz on 2012-08-20:
And as the answer indicates, there is a bug in current rosws. I'll edit my answer to show how to still add the output of roslocate.
Thanks a lot! I have another problem when I use " rows update ". Itry to correct here! Thanks again!
Exception caught during install: Error processing 'turtlebot' : 'ascii' codec can't decode byte 0xc3 in position 14: ordinal not in range(128)
ERROR: Error processing 'turtlebot' : 'ascii' codec can't decode byte 0xc3 in position 14: ordinal not in range(128)
The correct command (also used on the wiki page) is:
roslocate info turtlebot | rosws merge -
rosws update
Edit: Unfortunately, it seems like rosws has a bug right now that might prevent you from executing above command. Assuming you are using ROS fuerte, to assume the same effect as above, you can do the following:
roscd
roslocate info turtlebot >> .rosinstall
rosws update
Originally posted by Lorenz with karma: 22731 on 2012-08-20
