I'm facing a real weird problem with EKF Localization. The filer gives me wrong error every time the robot is in parallel with a landmark. I've debugged the code many times but failed to solve the problem however I found out where is exactly the problem occurs. The following picture shows the scenario. The robot moves in a circular motion. There are four landmarks. I have indicted in the picture where the filer gives me wrong angle for the estimated state. As you see, when the robot is in parallel with all landmarks, I got a wrong angle for the estimated robot's pose.
enter image description here
This is another picture shows how the estimated angle is wrong where the red circle is the estimated robot's pose and the blue one is the actual robot's pose.
I did also track the problem numerically. What I found out is that the estimated measurement of landmark # 4 is in the opposite direction of the actual measurement of landmark # 4.
i = 1 <---- landmark 1 <200,0>
est_robot =
    6.4545
   21.1119
    0.1246
Zobs =
  194.9271
   -0.2208
    1.0000
Zpre =
  194.6936
   -0.2333
    1.0000
real_robot =
    6.2069
   20.9946
    0.1188
Mubar =
    6.2844
   21.7029
    0.1201
i = 2 <---- landmark 2 <200,200>
est_robot =
    6.2844
   21.7029
    0.1201
Zobs =
  263.8102
    0.5982
    2.0000
Zpre =
  263.2785
    0.6239
    2.0000
real_robot =
    6.2069
   20.9946
    0.1188
est_robot =
    6.2901
   21.0100
    0.0155
i = 3 <---- landmark 3 <-200,200>
est_robot =
    6.2901
   21.0100
    0.0155
Zobs =
  273.0734
    2.2991
    3.0000
Zpre =
  273.1173
    2.4114
    3.0000
real_robot =
    6.2069
   20.9946
    0.1188
est_robot =
    6.2840
   21.0462
    0.0259
i = 4 <---- landmark 4 <-200,0>
est_robot =
    6.2840
   21.0462
    0.0259
Zobs =
  207.2696
    3.1272 <--- the actual measurement of landmark 4
    4.0000
Zpre =
  207.3548
   -3.0658  <--- this is the problem. (it should be 3.0658)
    4.0000
real_robot =
    6.2069
   20.9946
    0.1188
est_robot =
    6.0210
   20.8238
   -0.5621
and this is how I computed the angles.
For the actual measurements,
Zobs = [          sqrt((map(i,1) - real_robot(1))^2 + (map(i,2) - real_robot(2))^2)        ;
            atan2(map(i,2) - real_robot(2), map(i,1) - real_robot(1)) - real_robot(3);
        i];
     % add Gaussian noise
     Zobs(1) = Zobs(1) + sigma_r*randn();
     Zobs(2) = Zobs(2) + sigma_phi*randn();
     Zobs(3) = i;
 Zobs(2) = mod(Zobs(2), 2*pi);
 if (Zobs(2) > pi) % was positive
    Zobs(2) = Zobs(2) - 2*pi;
 elseif (Zobs(2) <= -pi) % was negative
    Zobs(2) = Zobs(2) + 2*pi;
 end
For the predicted measurements
q    = (map(i,1) - est_robot(1))^2 + (map(i, 2) - est_robot(2))^2;
    Zpre = [                                                             sqrt(q);
            atan2(map(i,2) - est_robot(2), map(i,1) - est_robot(1)) - est_robot(3);
        i];
     if (Zpre(2) > pi) % was positive
        Zpre(2) = Zpre(2) - 2*pi;
     elseif (Zpre(2) <= -pi) % was negative
        Zpre(2) = Zpre(2) + 2*pi;
     end
It seems to me that you did not consider the fact that angles are not just real numbers but cyclic ($+ \pi = - \pi$).
No. The two angles $3.1272$ and $-3.0658$ are rather close and thus these numbers look perfectly fine. The angle difference is $0.09 \equiv 5.17^{\circ}$.
When computing the difference between two angles, you need to make sure the results lie in $[-\pi, +\pi]$ (e.g. as described here).
  • $\begingroup$ ,I've wrapped the difference, so the angle falls in [pi,-p]. I've implemented the entire project in OpenGL and I'm facing same problem. I've wrapped the difference in [0,2pi] but I'm getting same problem. $\endgroup$
    – CroCo
    Jul 31, 2014 at 9:43
  • $\begingroup$ Well sorry, there is not much to say without more information. Again: Zpre and Zobs above seem fine, your bug is most likely in the code using Zpre and Zobs, which you did not paste. $\endgroup$
    – sebsch
    Jul 31, 2014 at 21:31
  • $\begingroup$ I'm using an algorithm that is stated in Probabilistic Robotics book. $\endgroup$
    – CroCo
    Aug 1, 2014 at 12:39
