I have some troubles to see the laser_scan in a simulation with two robots which have the same description file (urdf) in different group with different namespace.
I launch both in gazebo and works quite good, the robots looks ok but when I launch rviz to see the laser, I select the fixed frame and the target frame of the robot one, I select the robot_description of the robot one and the tfprefix of the robot one. The tf looks great.
I see the robot one in the center of the visual space in rviz. When I try to see the laser_scan, I select the correct topic but I nothing appear, the error is the next:
Transform [sender=/gazebo]
For frame [hokuyo_laser_link]: Frame [hokuyo_laser_link] does not exist
I think the problem come to rviz. Rviz look for the frame described in the urdf robot description and not look for the tf_prefix.
Here my launch file and my tree of tf:
<launch>
  <!-- send summit_xl.urdf to param server -->
  <group ns="summit_one">
      <param name="robot_description" textfile="$(find summit_xl_description)/urdf/summit_xl.urdf" />
      <node name="spawn_summit" pkg="gazebo" type="spawn_model" args="-urdf -param robot_description -x 0.0 -y 0.0 -z 0.5 -model summit_xl_one" respawn="false" output="screen">
      </node>
      <!-- Controller manager parameters -->
      <param name="pr2_controller_manager/mechanism_statistics_publish_rate" value="1.0" />
      <param name="pr2_controller_manager/joint_state_publish_rate" value="100.0" />
      <!-- Robot state publisher -->
      <node pkg="robot_state_publisher" type="state_publisher" name="summit_one_state_publisher" output="screen">
        <param name="publish_frequency" type="double" value="50.0" />
        <remap from="hokuyo_laser_link" to="summit_one/hokuyo_laser_link" />
        <param name="tf_prefix" type="string" value="summit_one" />
      </node>
      <!-- Diagnostics -->
      <node pkg="pr2_mechanism_diagnostics" type="pr2_mechanism_diagnostics" name="pr2_mechanism_diagnostics_one" />
      <rosparam file="$(find summit_xl_ctrl)/summit_xl_ctrl.yaml" command="load"/>
      <node name="summit_xl_ctrl" pkg="pr2_controller_manager" type="spawner" args="summit_xl_ctrl" respawn="false" output="screen"/>
      <node pkg="summit_xl_odometry" type="summit_xl_odometry" name="summit_xl_odometry_node" output="screen"/>
  </group>
  <group ns="summit_two">
      <node name="spawn_summit" pkg="gazebo" type="spawn_model" args="-urdf -param robot_description -x 2.0 -y 2.0 -z 0.5 -model summit_xl_two" respawn="false" output="screen" />
      <node pkg="robot_state_publisher" type="state_publisher" name="summit_two_state_publisher" output="screen">
        <!--remap from="joint_states" to="summit_one/joint_states" /-->
        <param name="tf_prefix" type="string" value="summit_two" />
      </node>
      <node pkg="pr2_mechanism_diagnostics" type="pr2_mechanism_diagnostics" name="pr2_mechanism_diagnostics_two" />
  </group>
</launch>
tf http://tinypic.com/view.php?pic=xngh01&s=6
tf:
Someone who has the same problem? What should I do with the ghost frames? Is there any way to tell what frame rviz should choose?
Thanks a lot.
Originally posted by pmarinplaza on ROS Answers with karma: 330 on 2012-08-01
Comment by pmarinplaza on 2012-08-02:
Ok, at last I find the solution. When the tree of tf works fine, we need to lauch rviz node with param like this: and another rviz node with
No this is not at all the rviz error. The issue comes from the gazebo_plugins package and in your particular case from the gazebo_ros_laser plugin.
Current implementation in gazebo_ros_laser.cpp is as follows:
240: // Add Frame Name
241: this->laserMsg.header.frame_id = this->frameName;
and earlier
100: this->frameName = _sdf->GetElement("frameName")->GetValueString();
This means that laser scans in the field frame_id of LaserMsg header got whatever you put in the frameName of your gazebo controller declared in urdf.
  <controller:gazebo_ros_laser name="gazebo_ros_laser_controller" plugin="libgazebo_ros_laser_relative.so">
    <hokuyoMinIntensity>101.0</hokuyoMinIntensity>
    <gaussianNoise>0.005</gaussianNoise>
    <alwaysOn>true</alwaysOn>
    <updateRate>20</updateRate>
    <topicName>scan</topicName>
    <frameName>hokuyo_link</frameName>
    <interface:laser name="gazebo_ros_laser_iface" />
  </controller:gazebo_ros_laser>
And therefore rviz looks how to tansform scans from the link hokuyo_link but it can only find /summit_one/hokuyo_link and /summit_two/hokuyo_link.
I can see in your launch file that you try to handle that with:
but remapping works only for nodes and topics names, not for tf transformations, we use tf_prefix for that.
The quick and dirty workaround for your problem is to make two copies of your urdf file: one declaring /summit_one/hokuyo_link as frameName and the other with /summit_two/hokuyo_link.
However the proper solution is to introduce tf resolving in gazebo_ros_laser before storing frame_id in message header.
This discussion is also valid for the rest of plugins in gazebo_plugins package. I will issue a ticket for this.
Originally posted by Jakub with karma: 1821 on 2012-08-02
Comment by Jakub on 2012-08-02:
With the double urdf description and later with the laser patch you can visualize two robots at the same time in one rviz instance.
Ticket issued: https://code.ros.org/trac/ros-pkg/ticket/5511
Comment by pmarinplaza on 2012-08-03:
Thanks a lot, I'm looking forward the next patch ;)
If I want use 20 equal robots, the replication of the urdf won't be the best solution. But, I think we start with 2 simple robots.
