Hello,
I am new to ROS and currently I'm following the tutorial of ROS. Everything went smooth till now. I am at tutorial: http://www.ros.org/wiki/ROS/Tutorials/UnderstandingNodes
At about in the middle you have to execute the command rosrun turtlesim turtlesim_node
. Which will starte a node called turtlesim, because no other name is provided. Then you have to run rosrun turtlesim turtlesim_node __name:=my_turtle
and execute the command rosnode list
In the tutorial there is a note below the laste command saying
Note: If you still see /turtlesim in the list, it might mean that you don't have $ROS_HOSTNAME environment variable defined as described in Network Setup - Single Machine Configuration.
Now I still see /turtlesim in the list, even after I try to kill it using rosnode kill turtlesim
. I however, believe, have the correct settings for Network Setup. After echoing the variables ROS_HOSTNAME (which value is localhost) and ROS_MASTER_URI (which value is http://localhost:11311)
Now can I just ignore this that /turtlesim was still in the list, even when it was closed? Because the ROS_HOSTNAME is definitly set correct.
-edit- maybe this can give some light on the matter at hand?
[22:54|0] $ roscore
... logging to /home/<user>/.ros/log/b4b75b6a-c61a-11e1-ab73-00216b29721e/roslaunch-<user>-29448.log
Press Ctrl-C to interrupt
started roslaunch server http://localhost:56819/
ros_comm version 1.8.10
SUMMARY
PARAMETERS
* /rosdistro
* /rosversion
NODES
auto-starting new master
Exception AttributeError: AttributeError("'_DummyThread' object has no attribute '_Thread__block'",) in <module 'threading' from '/usr/lib/python2.7/threading.pyc'> ignored
process[master]: started with pid [29464]
ROS_MASTER_URI=http://localhost:11311/
setting /run_id to b4b75b6a-c61a-11e1-ab73-00216b29721e
process[rosout-1]: started with pid [29477]
started core service [/rosout]
Originally posted by WG- on ROS Answers with karma: 109 on 2012-07-04
Post score: 7
