Hello together,
first at all, im a pretty ros-rookie.
Starting roscore occurs following failures:
faps@UbuntuBioMech:~$ roscore ... logging to /home/faps/.ros/log/a1b68836-ea2a-11e1-9b31-000c295e6a98/roslaunch-UbuntuBioMech-9916.log Checking log directory for disk usage. This may take awhile. Press Ctrl-C to interrupt Done checking log file disk usage. Usage is <1GB.
started roslaunch server http://UbuntuBioMech:45736/ ros_comm version 1.8.6
SUMMARY
PARAMETERS * /rosdistro * /rosversion
NODES
auto-starting new master Exception AttributeError: AttributeError("'_DummyThread' object has no attribute '_Thread__block'",) in <module 'threading' from '/usr/lib/python2.7/threading.pyc'> ignored process[master]: started with pid [9932] ROS_MASTER_URI=http://UbuntuBioMech:11311/
setting /run_id to a1b68836-ea2a-11e1-9b31-000c295e6a98 Exception AttributeError: AttributeError("'_DummyThread' object has no attribute '_Thread__block'",) in <module 'threading' from '/usr/lib/python2.7/threading.pyc'> ignored process[rosout-1]: started with pid [9945] started core service [/rosout
The ROS-Workaround for this problem didnt work.
Any Sugesstions what is going wrong? Many thanks ahead,
Dominik
Originally posted by rosrookie on ROS Answers with karma: 55 on 2012-08-19
This is not a restrictive error. It has to do with Python. For all my purposes, this has not been an issue to the system. Have a look at this answer.
Originally posted by allenh1 with karma: 3055 on 2012-08-19
