Hi. i'm trying to use this library <pcl/io/openni_grabber.h> (i have istalled the pcl library for Ubuntu from this link http://pointclouds.org/downloads/linux.html) in my script using ROS (version electric for Ubuntu 11.10) , but although i have included it in my script, when i make the file it doesn't work. Thank you
Originally posted by Roberta on ROS Answers with karma: 1 on 2012-04-11
Comment by karthik on 2012-04-11:
More info required, like what dd u do, what is the error displayed, your environment, OS, ROS version and PCL version. Only then people will be able to answer the question.
Still not clear as to what are you trying to do. Whats your script? Make file doesn't work, means any error? What are you trying to make?
