Hi, I'm trying to use the laser scan matcher package in my mobile robot. So I've performed numerous simulations on gazebo and everything worked great.
Now i'm performing the first tests with the physical robot, and a problem occurred, at high speeds (linear or angular) i't gives very good results but when traveling at low speeds it tends to drift allot, is this a issue that is to be expected because of the signal to noise ratio at slow speeds or my parameters wrong (mostly default). The environment is a normal office with the particularity that two office cabinets don't reflect the laser but other than that it's standard and with plenty of features for the icp . Tomorrow I gonna perform tests in a more controlled environment (less cluttered) so I can rule that out. If anybody had or has a similiar problem please let me know.
Thanks
Originally posted by fmarques on ROS Answers with karma: 92 on 2012-04-01
