Hi ROS community,
I'm trying to modify the android_tutorial_pubsub in hope that the roscore is started on my PC instead of on Android. I started roscore and set ROS_IP as well as ROS_MASTER_URI.
All I did to the code was delete
rosCore = RosCore.newPrivate();
rosCore.start();
try {
  rosCore.awaitStart();
} catch (Exception e) {
  throw new RuntimeException(e);
talker = new Talker();
nodeConfiguration.setMasterUri(rosCore.getUri());
and add:
nodeConfiguration.setMasterUri(URI.create("http://192.168.13.7:11311"));
so the code looks like this
 * Copyright (C) 2011 Google Inc.
 * Licensed under the Apache License, Version 2.0 (the "License"); you may not
 * use this file except in compliance with the License. You may obtain a copy of
 * the License at
 * http://www.apache.org/licenses/LICENSE-2.0
 * Unless required by applicable law or agreed to in writing, software
 * distributed under the License is distributed on an "AS IS" BASIS, WITHOUT
 * WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the
 * License for the specific language governing permissions and limitations under
 * the License.
package org.ros.android.tutorial.pubsub;
import java.net.URI;
import android.os.Bundle;
//import org.ros.RosCore;
import org.ros.android.MessageCallable;
import org.ros.android.RosActivity;
import org.ros.android.views.RosTextView;
import org.ros.node.NodeConfiguration;
import org.ros.node.NodeMainExecutor;
import org.ros.tutorials.pubsub.R;
import org.ros.tutorials.pubsub.Talker;
     * @author [email protected] (Damon Kohler)
    public class MainActivity extends RosActivity {
    //  private RosCore rosCore;
      private RosTextView<org.ros.message.std_msgs.String> rosTextView;
      private Talker tal
ker;
  public MainActivity() {
    super("Pubsub Tutorial", "Pubsub Tutorial");
  @SuppressWarnings("unchecked")
  @Override
  public void onCreate(Bundle savedInstanceState) {
    super.onCreate(savedInstanceState);
    setContentView(R.layout.main);
    rosTextView = (RosTextView<org.ros.message.std_msgs.String>) findViewById(R.id.text);
    rosTextView.setTopicName("/chatter");
    rosTextView.setMessageType("std_msgs/String");
    rosTextView
        .setMessageToStringCallable(new MessageCallable<String, org.ros.message.std_msgs.String>() {
          @Override
          public String call(org.ros.message.std_msgs.String message) {
            return message.data;
  @Override
  protected void init(NodeMainExecutor nodeMainExecutor) {
//    rosCore = RosCore.newPrivate();
//    rosCore.start();
//    try {
//      rosCore.awaitStart();
//    } catch (Exception e) {
//      throw new RuntimeException(e);
    NodeConfiguration nodeConfiguration = NodeConfiguration.newPrivate();
//    nodeConfiguration.setMasterUri(URI.create("http://192.168.13.7:11311"));
    nodeMainExecutor.execute(talker, nodeConfiguration);
    nodeMainExecutor.execute(rosTextView, nodeConfiguration);
  @Override
  protected void onDestroy() {
    super.onDestroy();
    // RosCore should be shut down last since running Nodes will attempt to
    // unregister at shutdown.
//    rosCore.shutdown();
when running, android is able to show Hello World n. so I assume android is then the two nodes talker and ros_text_view is able to connect the my master on PC. but as I called roswtf, i got the following error:
Loaded plugin tf.tfwtf
Package: beginner_tutorials
Static checks summary:
No errors or warnings
Beginning tests of your ROS graph. These may take awhile...
analyzing graph...
... done analyzing graph
running graph rules...
connection to [/android_gingerbread/ros_text_view] timed out
connection to [/rosjava_tutorial_pubsub/talker] timed out
... done running graph rules
Online checks summary:
Found 2 error(s).
ERROR Could not contact the following nodes:
 * /android_gingerbread/ros_text_view
 * /rosjava_tutorial_pubsub/talker
ERROR The following nodes should be connected but aren't:
 * /rosjava_tutorial_pubsub/talker->/android_gingerbread/ros_text_view (/chatter)
Now I wonder whether the connection really succeeded, and what could possibly cause this conflict. btw why can't I use rostopic pub to publish here?I tried rostopic pub /chatter std_msg/String abc but abc didn't show on my AVD. Did I miss anything?
Originally posted by rosdai on ROS Answers with karma: 61 on 2012-03-28
Comment by amigo on 2012-04-06:
Did you mean to comment out the line // nodeConfiguration.setMasterUri(URI.create("http://192.168.13.7:11311"));?
Comment by rosdai on 2012-04-11:
sorry the code was wrong. In my own code this line wasn't commented out
turned out this is a issue with AVD. If I use AVD, and need to forward port, which is very inconvenient.
also NodeConfiguration nodeConfiguration = NodeConfiguration.newPrivate(); set Master default to itself. change it to NodeConfiguration nodeConfiguration = NodeConfiguration.newPublic() and then nodeConfiguration.setMasterUri(URI.create("http://192.168.13.7:11311"));
Originally posted by rosdai with karma: 61 on 2012-04-11
